Replacing Front Brakes
Old Sep 7, 2011 | 06:45 PM
2wheelmatt's Avatar
2wheelmatt
Later tonight I am going to need to change out my front rotors and pads. This is the first time that I will have ever taken a wrench to this truck and I was wondering if there is anything that I need to be aware of before I get under the thing.
My abilities with a wrench are pretty solid, although the only vehicle I've needed to work on over the past few years is my 94 Jeep YJ.
I have done this a couple of times on my jeep without any troubles. I am just wanting to make sure that there isn't anything odd I need to be aware of.
Also, I'm curious what the average time needed for this repair is. Thanks in advance for any info that you all have.
The truck is a 2007 F150, 2wd, 5.4, 6 lug.
Matt
Old Sep 7, 2011 | 06:56 PM
bigunit54's Avatar
bigunit54
well mine is a 4X4 so it is a totally different animal, but I know the 2wd has a nut that holds the rotor on, this nut is a one time use nut so a new on has to be put on. The new nut is supposed to be torqued really high. I'm not sure of the exact number. do a search for 2wd brake job and you'll get some good info
Old Sep 8, 2011 | 11:14 AM
2004 xlt 5.4's Avatar
2004 xlt 5.4
The 2wd has a nut that holds the rotor on, this nut is a one time use nut so a new on has to be put on. The new nut is torqued to 295 foot lbs.
its not a hard job. You can go to any place that works on large trucks they will have the proper torque wrench. you need a 36 mm socket for the nut removal.
Old Sep 8, 2011 | 02:34 PM
2wheelmatt's Avatar
2wheelmatt
What about just using the impact wrench with my air compressor? It's rated at close to 400ft/lbs max torque.
Old Sep 8, 2011 | 03:19 PM
MCDavis's Avatar
MCDavis
Why don't I just use my hammer drill next time you need some dental work?
Use the proper tools, you'll thank yourself later on.
deezel
2004 - 2008 F150
Mar 31, 2014 06:53 PM
TexasDiesel97
2004 - 2008 F150
Jul 5, 2011 05:12 PM
hansont
Apr 18, 2008 03:57 PM
jwdenney2
2004 - 2008 F150
20
Sep 27, 2006 09:57 AM
cwb
Garage & Workshop
40
Feb 22, 2004 05:29 PM
