Replacing Front Brakes
Later tonight I am going to need to change out my front rotors and pads. This is the first time that I will have ever taken a wrench to this truck and I was wondering if there is anything that I need to be aware of before I get under the thing.
My abilities with a wrench are pretty solid, although the only vehicle I've needed to work on over the past few years is my 94 Jeep YJ. I have done this a couple of times on my jeep without any troubles. I am just wanting to make sure that there isn't anything odd I need to be aware of. Also, I'm curious what the average time needed for this repair is. Thanks in advance for any info that you all have. The truck is a 2007 F150, 2wd, 5.4, 6 lug. Matt |
well mine is a 4X4 so it is a totally different animal, but I know the 2wd has a nut that holds the rotor on, this nut is a one time use nut so a new on has to be put on. The new nut is supposed to be torqued really high. I'm not sure of the exact number. do a search for 2wd brake job and you'll get some good info
The 2wd has a nut that holds the rotor on, this nut is a one time use nut so a new on has to be put on. The new nut is torqued to 295 foot lbs.
its not a hard job. You can go to any place that works on large trucks they will have the proper torque wrench. you need a 36 mm socket for the nut removal. |
Originally Posted by 2004 xlt 5.4
(Post 10787439)
Originally Posted by 2wheelmatt
(Post 10788035)
What about just using the impact wrench with my air compressor? It's rated at close to 400ft/lbs max torque.
Use the proper tools, you'll thank yourself later on. |
