spindle nut
Old Mar 31, 2014 | 03:21 PM
deezel's Avatar
deezel
spindle nut
tightening 2005 f150 2wd front spindle nut to 295 ft. lb. spec and rotor locks up.not sure what to do.tighten till locks up and back off till free?thanks for any replies in advance
Old Mar 31, 2014 | 06:53 PM
ojai150's Avatar
ojai150
There is something wrong, why did you take off the nut in the first place ?
Did you replace the rotor ?
The nut basically keeps the rotor from falling off , their is no preload on the sealed bearings like on the old bearings.
Even if you tightened it to 395 lbs, it shouldn't effect the rotor turning.
By the way , did you put on a new nut like Ford instructs ?
ROBZ95XJ
Feb 9, 2013 03:07 AM
ray299
1997 - 2003 F150
Dec 6, 2011 02:45 PM
E150
Oct 3, 2008 12:41 PM
jwdenney2
2004 - 2008 F150
20
Sep 27, 2006 09:57 AM
tom2131968
1978 - 1996 Big Bronco
Aug 20, 2006 09:56 AM
