Please help with codes!!
Old Sep 5, 2011 | 06:56 PM
shawbran's Avatar
shawbran
I keep getting these codes up and can't figure them out can I please get some help here??
1994 Ford F Super Duty 460
556
558
212
332
542
Old Sep 5, 2011 | 07:09 PM
Hunt4Fun's Avatar
Hunt4Fun
OBD-II Trouble Codes - DTC Codes Car Repair for reference.
Old Sep 5, 2011 | 07:33 PM
subford's Avatar
subford
You have a OBD-I truck and not II.
Code 212, Somebody has installed the wrong ICM. They put in a Gray one and you need a Black one.
Code 558 & 332, You also have a bad EVR solenoid.
Code 336 & 542, You have a bad fuel pump relay or bad fuel pump.
Next time be more specific what the codes are, either KOEO, CM or KOER for a more accurate answer.
Old Sep 5, 2011 | 07:44 PM
shawbran's Avatar
shawbran
These were KOEO codes sorry about that. On the fuel pump one? It whines constantly when the key is on. I have changed the relay with no change would that mean a bad silenoid? Would any of the codes be why my check engine light keeps coming on while driving down the highway but as soon as a shutoff the key it disappears until I start driving again.
Old Sep 5, 2011 | 07:57 PM
shawbran's Avatar
shawbran
where is the EGR selinoid located?? Is the piece on top of the EGR valve
Old Sep 5, 2011 | 08:56 PM
rla2005's Avatar
rla2005
Courtesy of Paul Conanski
Old Sep 6, 2011 | 06:41 AM
subford's Avatar
subford
The 212 code is a CM only code. Replace with Black ICM.
332 code another CM only code, EGR valve did not open when told to. Most likely from the EVR solenoid not working.
542 KOEO, Bad fuel pump most of the time.
Also 556 CM or KOEO code again bad fuel pump.
558 KOEO code, bad wiring, plug or open coil in the EVR solenoid.
It means the fuel pump is running with a high load dragging the voltage low and causing the 542 and 556 codes.
Could be you need a new fuel filter or fuel pump.
Yes they would.
It is the EVR in the the photo above.
No that is the EVP sensor.
ol_red92
Mar 3, 2014 11:43 AM
Mike Norwood
Mar 23, 2009 09:19 PM
RBWiseman
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Nov 29, 2004 10:37 PM
AMDAP
1978 - 1996 Big Bronco
Oct 27, 2003 06:15 PM
Hank85713
1983 - 2012 Ranger & B-Series
Apr 18, 2002 02:31 PM
