Pulled Some Codes
Old Mar 2, 2014 | 03:12 PM
ol_red92's Avatar
ol_red92
Pulled Some Codes
So this afternoon i took the time to pull some stored codes and was wondering if you guys knew what route to take next or is in need of being replaced, i pulled
173
327
328
334
337
634
And another question is are all these EGR codes going to be in direct relation to the same part that is bad?
This is on the 92 302.
Old Mar 2, 2014 | 04:20 PM
subford's Avatar
subford
You need to tell us where you got the codes, KOEO, CM or KOER.
They can mean different things.
Old Mar 2, 2014 | 07:03 PM
ol_red92's Avatar
ol_red92
They are for the Key on engine off test
Old Mar 2, 2014 | 07:34 PM
subford's Avatar
subford
The 173 code is not a KOEO code but in KOER and CM it means system is rich.
327 is the opposite of code 334.
328 is the opposite of code 337.
You can not have opposite codes.
634 says the MLP sensor is out of range.
Are you sure you have three digit codes?
These do not sound right at all.
Old Mar 3, 2014 | 11:19 AM
ol_red92's Avatar
ol_red92
yeah im sure that is what is coming up as i have my own obd1 scan tool
Old Mar 3, 2014 | 11:28 AM
subford's Avatar
subford
Sounds like then you have a lot stored codes in CM then.
You need to clear the codes by grounding the STI wire, turn on the key and when the CEL (MIL) starts to flash remove the ground.
The the codes will be cleared.
Then turn the key off.
Old Mar 3, 2014 | 11:38 AM
joey2fords's Avatar
joey2fords
...does that code-clearing procedure work on an 89 4.9litre ?
Old Mar 3, 2014 | 11:43 AM
subford's Avatar
subford
Yes it does.
1911fan
6.7L Power Stroke Diesel
Jul 24, 2017 10:33 AM
bbryson
General Automotive Discussion
Jul 7, 2011 12:33 AM
djbeck88
17
Feb 2, 2011 05:00 PM
bocefusss
1978 - 1996 Big Bronco
Jun 6, 2007 04:09 PM
StevePA
1997 - 2003 F150
Apr 24, 2003 07:43 PM
