need help
Old Sep 5, 2011 | 05:25 PM
skynyrd1911's Avatar
skynyrd1911
need help
I'm new to this forum and my wife's 2003 sportrac has developed a problem. The left rear turn signal\brake light will not work. The tail light does. When you turn on the left turn signal the front bulb and the dash light flashes real fast. I have changed both, the front and rear bulbs with no luck. I've read on here about the tilt steering column deal. I have moved the steering column while operating the turn signal with no change. Any suggestions???
Old Sep 6, 2011 | 06:46 AM
shorod's Avatar
shorod
Welcome to the forum! If the problem were in the steering column I would not expect the front turn signal to work either.
I'd suggest you start by confirming whether or not you have voltage to the bulb socket for the turn signal. I'd suggest doing this using a test light to load the circuit. If possible, connect the test light ground lead to the ground for the bulb.
Has someone by chance wired in a trailer light connector and spliced in to the wires rather than using the pre-wired connector?
-Rod
Old Sep 7, 2011 | 11:14 AM
skynyrd1911
Truck was wired from the factory for trailer. I'll try and ck what you suggested. Thanks!
Old Sep 8, 2011 | 12:55 PM
jpmcglynn's Avatar
jpmcglynn
Even if the trailer harness was a factory install, I would still check that too. It's a likely place for a break in the connection or somewhere in that harness, especially since it usually isn't tied down as well as the rest of the wiring. If the rear turn signal doesn't work, I wouldn't expect it to work for the trailer either. If you have a trailer, plug it in and give it a test. If not, you can get a tester, or just use a volt-meter to test.
Old Sep 8, 2011 | 11:08 PM
jplinville's Avatar
jplinville
Did you check the offending plug to see if there's power? My guess is a bad ground.
nlemerise
13
Oct 14, 2011 03:46 PM
pressureelite
1997 - 2003 F150
Apr 25, 2010 04:18 PM
trulsu
Feb 16, 2010 06:58 PM
Fullcrew7.3
Jul 28, 2009 09:12 AM
briank
All Things Towing
Oct 27, 2005 11:25 AM
