Sponsored by: Real Truck
right turn signal
Old Feb 15, 2010 | 05:45 PM
trulsu's Avatar
trulsu
right turn signal
just got truck need help with one problem
right turn sinal works only when you push it to the lane change mode
front bulb, mirror work normal rear light flashes fast when lever is put all the way up to normal turn only rear bulb flashes fast and no indicator on dash I have replaced both front and back bulbs and flasher same result
left turn signal works normally Any ideas???
Old Feb 15, 2010 | 05:51 PM
Jigger2020's Avatar
Jigger2020
that's a good one, maybe check your trailer plug in,or might be your signal switch in the column, what happen's when you put the 4 way's on? Gigger
Old Feb 16, 2010 | 06:58 PM
trulsu's Avatar
trulsu
4 ways work as normal will check trailer plug but dont beleive it has ever been used
