How to remove vent window?
Old Sep 5, 2011 | 02:12 PM
SuperDuty93's Avatar
SuperDuty93
So ive noticed that my vent windows dont work very well. The handle is rusted on and they just dont work right. So i ordered new frames and glass.... Now how the heck do u take the old frame out?
Old Sep 5, 2011 | 03:23 PM
HIO Silver's Avatar
HIO Silver
It's rather involved cuz ya basically have to gut the entire door... The vent window frame will be last to come out.... '
might as well replace the seals and felts while it's waaaaaaay apart. Another "empty door" project is to clean and paint the interior surface - especially along the bottom where it can start to rust. 'might wanna apply some Dynamat before reassembly too.
Old Sep 5, 2011 | 03:31 PM
co425's Avatar
co425
+1 on the dynamat or equivalent. Also new insulation behind the panel. Makes a door go from bong when you shut it to a thud.
Old Sep 5, 2011 | 06:45 PM
SuperDuty93
Why is nothing easy.lol OHHHHH boy.... I guess this will be an all day project cuz i have to do both sides. And i will be replacing all felt and seals. Im tired of listening to the windows whistle!
Old Sep 5, 2011 | 07:08 PM
Ciin's Avatar
Ciin
Loosen the guide rail near the latch and remove the bolt with the spring at the vent window pivot point as well as the bolt just below the regulator. Roll the window partially down (not all the way).
You can remove the large window with out removing the regulator. Let it sit in the door. You can remove vent window at this point but the little bracket is a pain to remove with out removing the anti rattle strips.
Old Sep 5, 2011 | 08:25 PM
HIO Silver's Avatar
HIO Silver
Turn up the CD player and the whistling windows go away!
In comparison, IT IS EASY. Ya oughtta try working on a Porsche or Benz. They all use them damned plastic clips...and each one of 'em breaks when removed.
Patience, must have young Dentsider.
yeah but get ready for cut and scraped forearms.
Old Sep 5, 2011 | 08:29 PM
Ciin's Avatar
Ciin
Hehe it's just a flesh wound! Oh and don't forget the three little screws on the leading edge of the door
Old Sep 5, 2011 | 09:03 PM
crazy96863's Avatar
crazy96863
Does anyone know if vents on newer models fit into the dentsides? The design appears to be way better when it comes to sealing and security.
Old Sep 6, 2011 | 01:07 AM
starwriter's Avatar
starwriter
I also tinted my windows while they were out. It was easier for me that way.
Old Sep 6, 2011 | 06:51 PM
SuperDuty93
I plan on tinting the windows while they are out. Just have to find a good place do do it.... Anyone know what that would run? Also need the rear slider tinted.
Old Sep 7, 2011 | 07:16 PM
starwriter's Avatar
starwriter
I bought tint from wallyworld and did it myself. It was super easy and only $20.
Old Sep 7, 2011 | 08:54 PM
supercabfreak's Avatar
supercabfreak
just a thought i took some clear vinyl tubeing and cut it lengthways and sliped it on the edge around the acces hole to keep from cutting my arms apart
medicpg
Feb 8, 2014 09:58 PM
nates-new-old-f150
Mar 20, 2008 04:26 PM
ghunt
Feb 1, 2008 03:00 PM
baitmaster
Feb 2, 2006 06:17 AM
jvs65
1978 - 1996 Big Bronco
Mar 1, 2004 09:53 PM
