1978 - 1996 Big Bronco
Vent window remove ?
Old Mar 1, 2004 | 07:20 PM
jvs65's Avatar
jvs65
I bought a 90 bronco with a broken door vent window. How do I take the window and the frame out?
Thanks
Jonathan
Old Mar 1, 2004 | 08:23 PM
bigric's Avatar
bigric
Take off the interior door panel, then remove the big window from its regulator, turn it sideways, and remove it. Then you can unbolt the vent window frame from the door and remove it.
Old Mar 1, 2004 | 09:53 PM
_GEEZER_'s Avatar
_GEEZER_
That's correct. There are two phillips screws on the leading edge of the vent window frame, and one 7/16" bolt through the door metal holding it in which need to be removed.
On another note, when you pull the window out, there is a 4" long piece of loose weatherstripping at the top of the vent window and between the door frame. Don't let it fall it down inside the door.
