How to remove vent windows?
Old Feb 1, 2008 | 11:18 AM
ghunt's Avatar
ghunt
My vent windows are a bit rusty around the outside, I'd like to remove them and take care of that, but how do I do it?
Old Feb 1, 2008 | 12:22 PM
Conanski's Avatar
Conanski
You have to remove the main window to get the vent window out.
Remove the inner door skin and roll the window most but not all the way down.
Remove 2 screws on the forward leading edge of the vent window under the door seal and 1 below the vent window lock.
Pull the top of the vent window frame to the rear.
Reach into the door and slide the main window glass off the regulator arm, and remove from the door
Pull the seal from the main window channel attached to the vent window frame
Now turn the vent window frame 90 degrees and remove it from the door.
Pics here.. http://www.flickr.com/photos/motorst...7602815798457/
Old Feb 1, 2008 | 12:28 PM
quicklook2's Avatar
quicklook2
do not cut your hand on sharp metal when reaching in the open door panel.
do one side at a time and leave the other open to see how everything connects.
someone on this forum had the window come down and cut him bad.
Old Feb 1, 2008 | 01:29 PM
ghunt's Avatar
ghunt
Ah geez. Maybe I'll see if I can fix it on the truck then.
Old Feb 1, 2008 | 02:51 PM
mhg's Avatar
mhg
16 oz. ball peen
swing lightly
Old Feb 1, 2008 | 02:54 PM
phoneman91's Avatar
phoneman91
Originally Posted by mhg
16 oz. ball peen
swing lightly
Exactly--or as the low life that tried to steal my vehicle--a brick.
Old Feb 1, 2008 | 03:00 PM
quicklook2's Avatar
quicklook2
that was going to be my first answer.
hahaha
joedellcarter
17
Mar 19, 2017 11:20 PM
taylorjgreen
Feb 5, 2011 09:43 AM
breakfastpoo
Aug 5, 2006 03:00 PM
76shortbed
Mar 3, 2006 10:12 PM
