2000 7.3 PSD
Old Aug 29, 2011 | 07:38 AM
cherrob123's Avatar
cherrob123
2000 7.3 PSD
My truck was going down the road just fine and all of a sudden it just quit. I got the truck started again no problem, but when I pushed the brake to put it into gear, it would die again.
After about three or four times of this happening, it started and drove home just fine.
I replaced the alternator two months ago and the problem is just now occurring. The boot covering the main power wire from the alternator had dry rotted so I used electrical tape instead to cover the connection.
The connections to the alternator are fine and very tight. Could a loose connection to one of the batteries cause this to occur? Especially when I push the brake pedal?
I have a code reader and I have zero fault codes and no CEL.
HELP!!
Old Aug 29, 2011 | 08:05 AM
timmyboy76's Avatar
timmyboy76
CPS
Have you replaced it or done the recall on it yet?
Old Aug 29, 2011 | 08:29 AM
cherrob123's Avatar
cherrob123
I haven't ever brought the truck in for any recalls. I do not know what the CPS is.
I've had the truck since 2001 and it has 320k on it. Can you give me some info on that part and which recall you think I need to be looking at?
Thanks
Old Aug 29, 2011 | 09:05 AM
SGnAZ's Avatar
SGnAZ
Thanks
Here's how to change the cps
Welcome to guzzle's CPS R&R Web Page<
Guzzle is out of stock,check around for another vendor
Old Aug 29, 2011 | 09:41 AM
cherrob123's Avatar
cherrob123
Ok...you guys are a life saver. That is exactly what my truck is doing.
I will get a new CPS and install. I am guessing I should stay away from the gray colored one if possible?
Old Aug 29, 2011 | 11:12 AM
DND58's Avatar
DND58
And here's a link to check your truck for outstanding recalls.
If the CPS recall is still valid, Ford will replace your CPS no charge.
Old Aug 29, 2011 | 02:45 PM
cherrob123's Avatar
cherrob123
I didn't see any link in your reply for recalls DND, but that's ok. I did a search and didn't find anything. I'm sure it wasn't very exhaustive, but that's ok too.
The web site for GUzzle was out of the CPS, but my local Dealer has 4 in stock and is wanting $28.30 for one. He said that it's gray, but it's the newest one that they make and not like the old gray one that caused all the problems. He told me that the black one was discontinued and that's probably why Guzzle doesn't have any in stock.
This should work out nicely.
You guys are the best.
Backwoods351
Jul 2, 2014 08:45 AM
stroker870
19
Sep 18, 2009 03:24 PM
trigeek
Jul 15, 2009 11:01 PM
FroggF350
13
Sep 19, 2008 07:35 PM
02f250fx4
Jun 11, 2007 05:28 AM
