Need help ASAP!!!
Old Jul 2, 2014 | 07:37 AM
Backwoods351's Avatar
Backwoods351
Need help ASAP!!!
Hey guys, I'm having a problem.
And I'm new to diesels
I'm working on a 1996 f250xl with the 7.3l powerstroke and the cps and the alternator went out at the same time. They both we're replaced. Now the truck burns up every new alternator that is put on it. This happens as soon as you try to start it. I am buying from my boss who got from another guy, so I don't know much about the truck.
I have traced all the wires that I know to check for a bare spot or a short but can't find anything wrong. The alternator tested good at orileys, but on the truck it's putting out 25 volts. Please help me figure this out.
Old Jul 2, 2014 | 07:43 AM
Robbieo11's Avatar
Robbieo11
Are the batteries hooked up wrong Sounds like u have hooked them up as a series circuit. Is the alternator wire going to batteries or solenoid. My truck it is going to solenoid.
Old Jul 2, 2014 | 07:47 AM
Backwoods351
Yes the are hooked up as a series circuit. But it was like that when it got here. I should mention that this was a utility truck and used to have a crane and stuff like that.
Backwoods351
Yes they are hooked up as a series circuit. But it was like that when it got here. I should mention that this was a utility truck and used to have a crane and stuff like that.
Old Jul 2, 2014 | 07:54 AM
Backwoods351
It's going to the solenoid
Old Jul 2, 2014 | 07:56 AM
Robbieo11's Avatar
Robbieo11
I think i would isolate the battery system ie make it stock
Remove extra cables
Old Jul 2, 2014 | 08:00 AM
quesey's Avatar
quesey
try hooking them up parallel and see what happens
Should have 1 hot that feeds from both batt and a ground from both to the motor
Old Jul 2, 2014 | 08:03 AM
quesey's Avatar
quesey
Bet that sombitch spins fast
Old Jul 2, 2014 | 08:15 AM
Backwoods351
Everything is in order there
Old Jul 2, 2014 | 08:35 AM
Backwoods351
What do you mean?
Old Jul 2, 2014 | 08:44 AM
Backwoods351
Got it figured out. It was the starter solenoid. Thanks for the help guys.
Old Jul 2, 2014 | 08:45 AM
quesey's Avatar
quesey
with it showing 25 volts
That's whats burning up everything these are 12 volt trucks.
25 v going to starter will spin the crap out of it
In the old days we had a solenoid on a 79 f350 that would run everything on 12 but it would send 24 to the starter with the extra battery when going to start it then back to 12 to charge both
Cant find it anymore that I've been able to look around
diamond mike
Mar 28, 2011 04:03 PM
Midwest Dually
Feb 22, 2011 06:40 PM
Donutrcng
Jun 25, 2009 01:04 PM
badacid
Jan 11, 2009 04:53 PM
