Well before the initial boil over it drove fine for months. When I changed out fluid i only about 2-3 qts came out then i filled let it isle qbout 30 min then I drove it twice for about 15 minute each to let the overflow come out n it looked like a water hose when it started leaking out today
The trans should hold 13.5 when drained! that includes the TC and about 5 quarts when the pan is dropped. It is starting to sound like you have blown a piston o ring and its causing a bad slippage condition making the fluid over heat.
