Fuel Pump Problem?
Old Aug 25, 2011 | 12:17 PM
jfmaz's Avatar
jfmaz
Fuel Pump Problem?
My 87 Super Cab 4x4, 2.9 is making a growling noise coming from the fuel tank. The strange thing is that it continues for a few seconds after the ignition is off. I was thinking the fuel pump in the tank, it kind of sounds like the sound a worn bearing would make as it badly cavitates? But it seems weird to me that it would contiue after the pump power is off.
If I cycle the pump with the key, it still does it after the pump turns off? Doesn't seem like a fuel pump would run on after the power is off, as it would have resistance and stop immediately??
Anyone with thoughts on this.
Oh yeah, till now (and at present) I don't seem to have a fuel delivery problem.
Old Aug 25, 2011 | 08:28 PM
Rackster's Avatar
Rackster
Not sure
jfmaz,
You may want to do an Advanced Search under the Search tool to see if you can find similar symptoms. I did a quick search and used "fuel pump" + noise and got hundreds of hits. If you can refine the search, you might find what you are looking for.
I read about 6 possible items, but only this one sounded similar.
https://www.ford-trucks.com/forums/1...ing-noise.html
I'm not familiar with the fuel pump construction, but maybe this helped.
Good luck!
Kevin
Old Aug 25, 2011 | 09:05 PM
Dutter's Avatar
Dutter
if its the fuel pump i gota brand new pump sitting here at my house $40,, Because it is weird how its growling
Old Aug 25, 2011 | 09:19 PM
jfmaz's Avatar
jfmaz
Thanks to both of you, I will search, but have bought a pump to put in saturday. Its the pump only, so if it doesn't match up tho the pump that's in there I will need to buy the complete unit with gauge sender attached. Guess ill know better saturday afternoon.
Jeff
Old Aug 25, 2011 | 10:19 PM
Dutter's Avatar
Dutter
Yeah it should be just the pump the sending unit wouldnt make a sound like that
qman
Mar 12, 2021 07:06 AM
ford7.3l
Aug 17, 2010 03:22 PM
DAI532
27
Sep 24, 2009 08:34 PM
fjbcarver
1978 - 1996 Big Bronco
Nov 4, 2004 08:14 AM
rhetor
Jan 14, 2003 11:27 PM
