Ticking noise?
Old Aug 9, 2011 | 09:03 PM
BigBody's Avatar
BigBody
Ticking noise?
Trying to figure out what I thought was an exhaust leak....
I had put aluminum collector gaskets in and it still made the noise. Took it to the exhaust shop and they welded it solid. What a waste of money.
The noise is still there and not sure how to target it.
It gets louder with higher rpms. Sticky lifter? Flywheel?
Any easy way to narrow it down?
Old Aug 9, 2011 | 10:05 PM
devino246's Avatar
devino246
Ive got the same noise. The only sound at idle comes from the part that hooks up to the smog pump, what ever thats called, its right next to the coil.
Old Aug 9, 2011 | 10:31 PM
RWENUTS's Avatar
RWENUTS
Use an old chunk of garden hose or wood broom handle and use it as a stethoscope. Easy to find the source of the tick. I use the broom handle. Put one end on the motor and press the other end right behind your ear.
Old Aug 10, 2011 | 02:30 AM
mjshagnasty's Avatar
mjshagnasty
Mechanical fuel pump?? It seems reasonable
Old Aug 10, 2011 | 10:10 AM
devino246's Avatar
devino246
Do those make a ticking sound?
Ill take the truck for a drive today and see if I cant get the sound on video.
Old Aug 10, 2011 | 12:32 PM
BigBody's Avatar
BigBody
I'll try the broom stick truck next time I am working on it. I'd like to get it repaired or quieted down.
Old Aug 10, 2011 | 12:59 PM
mjshagnasty
It would make sense to me that they would. It's an arm that's gets pushed up and down. The faster the rpm the more it moves up and down. Maybe someone that knows a little more may chime in.
Old Aug 10, 2011 | 01:03 PM
devino246's Avatar
devino246
Mine probably is an exhaust leak. I cut the cat off a while ago to take the insides out and then welded it back on, I was never able to get every little pinhole closed up. Have a small hole in the muffler too. My whole exhaust system is rusting from the inside out
Old Aug 10, 2011 | 01:17 PM
RWENUTS's Avatar
RWENUTS
Fuel pump rod usually sounds like a dull slap slap noise. Or sometimes a rattle noise. Kinda muted cause they're inside.
A common tick noise at idle that increases with rpm could be a cracked flexplate.
Old Aug 10, 2011 | 06:31 PM
BigBody's Avatar
BigBody
Is there an easy way to confirm its the flywheel? Just a visual inspection? Will it do any harm? PO said he put in a new clutch. Perhaps they didn't replace the flywheel or damaged it in the process.
Old Aug 10, 2011 | 07:15 PM
RWENUTS's Avatar
RWENUTS
Sorry. Flexplate is for auto tranny. Your flywheel should never crack. Listen around with the broom handle. You'll find it.
Old Aug 10, 2011 | 07:38 PM
NW 150's Avatar
NW 150
mine has a slight lifter tick but that's only at idle and quiets down a little after it's warmed up
Byoung Oh
2004 - 2008 F150
Jun 12, 2018 11:04 PM
salsathe4th
1997 - 2003 F150
Jun 30, 2014 12:07 AM
steel1970
May 21, 2008 03:25 PM
hi-jacker
Nov 25, 2006 07:38 AM
JaredP
1983 - 2012 Ranger & B-Series
Nov 15, 2005 08:14 AM
