Coolant Flush
Old Aug 31, 2011 | 01:53 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Originally Posted by motorking
Hello,
I am the Tech manager at prestone coolants. You should replace the oil cooler first beofre the flush, otherwise you will still be getting oil in the coolant. Use Prestone HD flush or the V-9 from the Ford dealer, follow that with distilled water and powdered dishwashing detergent. It does an incredible job getting al traces of oil out of the system. Flush thoroughly with clean water. I recommend Prestone Red HD ELC coolant.
What is it about the powdered dishwashing detergent that makes it the wise choice?
Old Aug 31, 2011 | 01:57 PM
motorking's Avatar
motorking
Actually two things- It is designed to break the surface tension between the dirt and the surface its clinging to, that is why its gets your dishes so clean. Second, it contains a mild and non harmful degreaser (think bacon fat) that will suspend the oil and other crap in your cooling system so you can drain it out. This is not a tick I leanred at Prestone, its an old mechanics trick from when trans coolers would leak trans fluid into cooling systems. Dropping that calgon in there really works.
Old Aug 31, 2011 | 03:57 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
This is one of the GREAT things that happen at FTE..... we get the BEST advise!! From all the pro's. We know they are pro's when they get questioned by a knowledgeable member and they don't get bothered by it! They come back with a logical response!!!
Thanks motorking! and you too Steve!
Old Aug 31, 2011 | 10:24 PM
SoCalSuperDuty03's Avatar
SoCalSuperDuty03
Originally Posted by SteveBricks
You wear a lot of hats...I thought you were the tech manager @ Fram? https://www.ford-trucks.com/forums/9...ml#post8963919
Or was it Autolite? https://www.ford-trucks.com/forums/1...ml#post9783260
Steve, I thought you busted motorking red (coolant) handed! He does wear a lot of hats apparently!
JJ1101
Aug 19, 2014 12:27 PM
cabloom300
Dec 29, 2013 02:57 PM
bdostone
15
Jun 7, 2013 11:20 AM
craypc
Apr 4, 2013 07:04 AM
bohrer54
Jul 15, 2012 08:23 AM
