timing gears
Old Apr 3, 2003 | 11:23 AM
cryptonik420's Avatar
cryptonik420
timing gears
How hard/expensive is it to replace them? I figure at 150k it's due for a gearset change...am I wrong?
Old Apr 3, 2003 | 04:46 PM
Ford_Six's Avatar
Ford_Six
timing gears
I would definitely replace the gears, especially if they are the stock fiber ones. Not too hard to do, p/s pump, a/c compressor (if you have one) and crank pulley have to come off. Removeing the radiator makes it easier.
There is the possibility that, if they are fiber gears, you may have to pull the cam out. This is simple because the material can break when you put the stress of pulling on it, leaving you with nothing to grip. Personally, I use steel gears only. I hate the thought of having a fiber one come apart. Just ask chas1234 about that.
(edit)- Steel gears generally run $35-40, while the fiber ones are usually $50+. Check the online store here, they may have them available.
Old Apr 4, 2003 | 08:55 AM
cryptonik420
timing gears
awesome!
Old Apr 4, 2003 | 10:59 AM
tetraruby's Avatar
tetraruby
timing gears
Jared, not to be a smarty one, but why pull the P/S pulley or the AC, they don't seem to be in the way..
Old Apr 4, 2003 | 06:05 PM
daerhldgs2's Avatar
daerhldgs2
timing gears
If you're going to pull the timing gears be sure to remove the bolts on the plate behind the cam gear that keeps the cam from walking and the us that plate to pull the gear i.e. don't put the jaws of the puller on the fiber gear but rather the steel plate behind it and you should have no problem.
Old Apr 4, 2003 | 10:01 PM
broncr's Avatar
broncr
timing gears
I put in steel gears when I rebuilt. One thing I did notice was a kind of soft "blower whine" sound afterwards which (I think) is part of why the synthetics are an option - they're quieter. I got used to the sound (20k & no problems). It hasn't scared anybody else yet...in fact most of the other guys can't even hear it.
Old Apr 4, 2003 | 10:40 PM
Ford_Six's Avatar
Ford_Six
timing gears
Tetra, IIRC, both use bolts that also hold the timing cover in place, and the brackets get in the way of removing the cover.
I have steel gears on my truck, and they make some noise. Actually, tooling down the road, you hear the gears more than the exhaust. Kinda cool when I drive around in 4-low (with the hubs unlocked), all the gear noise sounds like a massive blower.
Old Apr 5, 2003 | 12:22 AM
tetraruby's Avatar
tetraruby
timing gears
HA! I forgot about those two, three? bolts. I reread your post and assumed you were talking the pulley not the bracket. Doh.
Old Apr 5, 2003 | 08:12 AM
broncr's Avatar
broncr
timing gears
Originally posted by Ford_SIX
I have steel gears on my truck, and they make some noise. Actually, tooling down the road, you hear the gears more than the exhaust. Kinda cool when I drive around in 4-low (with the hubs unlocked), all the gear noise sounds like a massive blower. [/B]
'Glad I'm not the only one hearing that sound. I'll have to admit, it had me a bit worried - early on.
russellkr
Nov 2, 2002 11:18 AM
beartracks
Oct 18, 2002 02:20 PM
dale i
Sep 22, 2002 09:37 AM
rogwelch
Feb 12, 2000 11:29 PM
Jan 28, 2000 06:08 PM
