1978 - 1996 Big Bronco
transmission problem
Old Aug 23, 2011 | 02:53 PM
cbpadget's Avatar
cbpadget
i have a 91 bronco 5.7L and the other day a problem showed up. as i was coming up to a stop sign the bronco didn't downshift all the way into first gear, it stayed in a higher gear and stalled. i put it into park and started it back up and it ran fine until the next time i slowed down when it did it again....the transmission was rebuilt by a ford dealership and has maybe 1500 miles on it. i did add about 1/2 qrt of fluid to it but didn't seem to make a difference at the time. drove it today and it did fine. any ideas?
Old Aug 23, 2011 | 06:27 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Staying in a higher gear won't make it stall. The torque converter not unlocking when it should will make it stall.
There are several potential causes: Low trans fluid, loose/missing internal filter, worn/missing seals, or a worn pump.
F350dog
Apr 13, 2016 07:35 PM
bj3hedrick
Aug 12, 2015 09:02 AM
jas88
Jun 17, 2010 06:02 PM
ITA47
Aug 24, 2009 09:11 AM
s knox
Feb 21, 2003 10:32 PM
