gp prob
Old Aug 22, 2011 | 05:49 PM
toddpyles33's Avatar
toddpyles33
gp prob
ok dumb question but my gp system isnt working proper. all 8 plugs test good. wts comes on but for like 20 secs. glowplugs do not feel warm at all. and hard to start. i figured relay was bad. replaced no luck. so i tested the terminals and everything gets power except gp wire. but oddly ground wire is carrying current. which pretty sure it shouldnt right? thinking gp controller crossed somewhere. any way to rig aound without having to replace atleast for temp purposes
Old Aug 22, 2011 | 07:00 PM
tecgod13's Avatar
tecgod13
Did you read the two stickies at the top of this forum? One is for the early glow system, the other for the later glow system.
Read whichever one applies to your truck, then report back.
Old Aug 22, 2011 | 07:27 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
That is exactly how mine works and it works just fine.
How did you test your plugs?
Old Aug 22, 2011 | 07:57 PM
toddpyles33
i have read through it. is the ground wire supposed to powered when glow plugs should be heating. they do not get hot that wire shows no juice. i am just using a lil volt tester. thats how i checked gps. they all lite up. wts light stays on extremly long tho. and gpsdont get warm at all. and hard to start. on top of that somethings making my gauges work all funky. pegging out or not at all.
Old Aug 22, 2011 | 08:41 PM
'94IDITurbo7.3
What do you mean exactly? do they all cycle like the gauges do in new vihicles?
Old Aug 22, 2011 | 11:02 PM
toddpyles33
gp prob fixed bad controller. by passed it for temporary. how much is a new controller and any brand better?
and the charge gauge works and temp now. but no tach, oil pres pegged out high, fuel pegged out over full running. key on NR the fuel gauge pegged oil resets to zero, tach bumps like its ready to go. key off the oil press always returns to middle of indicator. tried to diff dashes. same thing. fuses all good. even fuse links. dont knw if adding a ground somewhere close would help
Old Nov 11, 2011 | 05:46 PM
toddpyles33
All problems now fixed. Dash was a gasoline dash not diesel. found one at junkyard 15 bucks all gauges work except fuel gauge. Also found the gp controller. They didnt know what it was so it was only 5 BUCKS! cheapest fix ill ever have lol. gps work truck starts and runs great.
Old Nov 11, 2011 | 06:05 PM
Aune163rd's Avatar
Aune163rd
thats great, what kind of GP's are they? Motorcraft Beru?
Old Nov 11, 2011 | 06:14 PM
'94IDITurbo7.3
toddpyles33,
once the engine is warm how long does the WTS light stay on for? ie, you go into a store, come back out and WTS light time =?????
Dbailey
24
Jan 17, 2012 02:15 PM
Ruebna
18
Feb 13, 2010 12:08 PM
baddarryl
Nov 20, 2007 05:41 PM
pabs
Dec 18, 2006 08:31 PM
KillerF250
Dec 12, 2004 07:07 PM
