Disabling Glow Plugs
Old Nov 20, 2007 | 08:13 AM
baddarryl's Avatar
baddarryl
To disable the glow plugs for purging air out of the fuel system, which wire is the ignition to relay that needs to be unhooked? Thank you. All plugs reading about .6 ohms. Replacement time?
Old Nov 20, 2007 | 09:56 AM
mikeismadness's Avatar
mikeismadness
I'm not sure what to do...do u know where the solenoid for the glow plugs is becuase i would like to hook mine up..its tgettin cold here and i have to spray ehter to start it
Old Nov 20, 2007 | 10:24 AM
PLC7.3's Avatar
PLC7.3
No need to disconnect/disable GPs for fuel purging... they will just cycle as normal with no harm. If you do not want the start then disconnect the FSS on the IP.
If you have 2 or more bad GPs, the controller may not cycle at all.
Two problems that occur with the solid state ( 1987 to 1994 IDI engines ) GP systems. If a GP burns out ( circuit resistance goes up ), the controller cycles the GPs at a faster rate which doesn't let them get to max operating temp. If 2 or more GPs fail, the controller may not cycle the GPs at all ( very rapid or no clicking heard ). When you check the GPs, use an ohmmeter. A high resistance ( not necessarily burned out ) GP can cause circuit resistance to go up and the controller will then cycle the GPs too fast. You probably will not find this problem with a test light. Resistance spec for GPs = .5 to 1 ohm cold. Second problem. A poor controller ground ( black wire attached to valve cover stud ) will cause the controller to leave the GPs on longer, often damaging or failing them. If you are having mulitple GP failures, I would check closely the controller ground. Now the confusing part. Bad ground --> longer GP on time ( slower cycling ). Burned out GPs --> faster cycling If you have both situations, it may appear that the controller is cycling the GPs at the proper rate. Bad ground slows it up while the burned GPs speed it up ---> normal cycling. The system acts/sounds like it's working normally, but you have a hard starting concern.
By........DieselDon
Glow plug torque is 12 ft lbs, I always use antisieze on the threads.
If you fellas put up truck info we could help you find things...
Old Nov 20, 2007 | 11:51 AM
baddarryl's Avatar
baddarryl
Would all GP's testing as .6 ohms cause increase voltage being drawn sufficient to melt the wiring feeding the Controller?
Old Nov 20, 2007 | 05:41 PM
Dave Sponaugle's Avatar
Dave Sponaugle
At .6 ohms the power the glow plug draws is 20 amps.
That is 4 amps lower than what they would draw at .5 ohms.
The higher the resistance, the lower the current draw gets.
Remove the connectors from all the glow plugs, but try to not disturb the harness much.
Now see what you have for an ohm reading on the harness.
There must be a short somewhere.
Y2KW57
59
Jan 29, 2017 01:44 PM
mattdoc88
Jun 24, 2015 11:44 PM
Florida F250
19
May 26, 2015 07:31 PM
galen4216
Jan 26, 2012 09:52 AM
1990FordF250Diesel
21
Aug 29, 2011 03:52 PM
