Check Engine Light
Old Aug 21, 2011 | 04:58 PM
Johnny_Blaze's Avatar
Johnny_Blaze
Check Engine Light
I was driving my 05 Excursion up from Myrtle Beach (hauling a TT) and my check engine light came on. I took it over to AutoZone to get the code read and it came out with "Injector Circuit Low" on all 8 cylinders. Is this a case of me need to put some injector cleaner in, or is this much worse? I would prefer to hear from the FTE Experts before taking it into the dealership.
Thanks so much!
Old Aug 21, 2011 | 05:01 PM
npccpartsman's Avatar
npccpartsman
It means your FICM has basically failed. Check out FICM Repair.com - Your Source for FICM Repair before you take it to the dealership. Ed does good quality repairs for a VERY reasonable price.
Old Aug 21, 2011 | 05:04 PM
Johnny_Blaze
After doing a search, I found that I didn't really give a lot of information.
There are no modifications to the truck.
Engine SOUNDS fine and runs fine. Starts up fine and no white/black smoke.
I did stop a a travel plaza and filled up on the "tractor" diesel from one of the semi-truck pumps. My personal belief is that this may have been a factor since the issue is affecting all 8 cylinders.
The truck ran strong all the way down (10hr haul) and all the way up until I filled up with that diesel, which is shortly displayed the light.
All temps recorded normally and fluid levels were all fine.
Old Aug 21, 2011 | 05:07 PM
npccpartsman
Sorry, but it's not indicitave of poor fuel quality, it's electrical codes and when you get all 8 with a good running truck it USUALLY means your FICM is bad. There is a procedure in the tech folder at the beginning of this forum that gives the test procedure.
Johnny_Blaze
In addition, the truck continues to start and run fine.
Old Aug 21, 2011 | 05:08 PM
Rusty Axlerod's Avatar
Rusty Axlerod
^^^^^_____+1
Old Aug 21, 2011 | 05:41 PM
dchamberlain's Avatar
dchamberlain
Check your FICM like these fine folks have suggested. Or prepare to replace it AND all 8 injectors. A failing FICM will take the injectors with it.
Old Aug 21, 2011 | 05:49 PM
BLADE35's Avatar
BLADE35
^^^^^^^X2 been a few on here in the same boat those codes are a positive ID on a bad FICM
also check your batts and alternator make shure they are good they can be a contributing factor in FICM failure
I wouldnt put it off to long you dont want to damage injectors
at least now you have options
test it if you want
https://www.ford-trucks.com/forums/8...procedure.html
heres one to fix it
https://www.ford-trucks.com/ford-manuals/FICM.pdf
and another to fix it
https://www.ford-trucks.com/forums/9...procedure.html
fda7709
Mar 20, 2015 07:02 PM
lundman
6.7L Power Stroke Diesel
15
Dec 31, 2014 07:39 AM
ford1183
28
May 25, 2008 07:57 PM
barnbuoy
Aug 25, 2007 09:22 PM
papa737
Mar 6, 2006 11:40 AM
