the hub form hell
Old Aug 22, 2011 | 07:51 AM
joe f350's Avatar
joe f350
i have a ball joint 60 not king pin
Old Aug 22, 2011 | 05:40 PM
tecgod13's Avatar
tecgod13
Ok, didn't know that. For the ball joint ones, I think there is more that can be adjusted (at least simpler to adjust) than the king pin version. For the kingpins, only toe can be adjusted without modification or adding parts. Usually ball joints have adjusters to change the caster and camber as well. So if your ball joints are good, then get the alignment checked.
wyomingbs
Dec 31, 2017 03:16 PM
WhyFord
1978 - 1996 Big Bronco
Oct 19, 2016 07:25 PM
aRKToS
May 14, 2009 06:42 PM
rmalottwtes30
Apr 11, 2009 05:36 AM
77f100rcsb2wd
Jan 7, 2009 09:57 AM
