Power Window Question
Old Aug 18, 2011 | 01:03 PM
aft2005exp's Avatar
aft2005exp
Here is the question re: '05 EXP EB 4x4 118k miles. Slow power window in front passenger door, either master or door switch.
I anticipate that it has something to do with motor, in the door since the speed is consistent on which switch is used to open and close the window. Is there a simple fix that anyone knows of? Or is is just time to replace the window motor?
Thanks
Old Aug 18, 2011 | 02:22 PM
alloro's Avatar
alloro
You can remove the motor, disassemble it, grease the bearings/bushings, and clean the brush and commuter ring contacts. If you'd rather not bother, then just replace the motor.
mike L
Sep 23, 2013 09:42 AM
sparkyrhett
May 7, 2007 02:21 PM
aMw_fl
Apr 13, 2007 12:55 PM
Dutch123
1978 - 1996 Big Bronco
Nov 22, 2004 09:32 PM
