2004 Expy Noise
Old Aug 18, 2011 | 08:57 AM
nagetech's Avatar
nagetech
2004 Expy Noise
Howdy everyone!
Hope you guys can steer me in the right direction.
I've had this noise in my truck for some time now, and can't quite seem to figure it out. On dry/hot days, when coming to a stop with the truck, I hear a clunk noise I suppose you can say. When that Happens, I feel a slight vibration under my feet. It happens lets say 3 out of 5 times or so. Recently now when at a complete stop and I start to take off, I hear a groan as the truck starts going, but only @ a complete stop. On rainy days, all the above noises are non-existent! No clunk no groan no nothing (the way it should be)!
I've had it looked at a few times by the ford dealership and a private mechanic and so far no dice. So far I've had:
Slip Yoke replaced and greased properly
Sway bar bushings replaced
Both mechanics have checked out the front end and everything is tight with no slop at all. This noise is driving me nuts! I'm hoping someone here has had the same or similar issue and can help me out!
I was thinking maybe dried up ball joins causing this?
Any help would be appreciated!
Old Aug 18, 2011 | 10:23 AM
alloro's Avatar
alloro
2wd or 4wd?
How many miles since the tranny fluid/filter was changed?
Old Aug 18, 2011 | 10:30 AM
nagetech's Avatar
nagetech
4wd and I did it about 8k miles ago or so. Everything was healthy while the pan was dropped
Old Aug 18, 2011 | 01:49 PM
alloro's Avatar
alloro
Originally Posted by nagetech
4wd
In that case, I would suspect the front drive shaft or the front differential.
Old Aug 18, 2011 | 01:51 PM
nagetech's Avatar
nagetech
Hum...never thought of that.... Totally changes what I was looking at myself....
What exactly should I be looking for ?
Old Aug 18, 2011 | 02:18 PM
alloro's Avatar
alloro
A worn front u-joint, lack of grease in the drive shaft slide, a bad bearing in the differential, a bad CV joint in a front half shafts.
This vibration under your foot is coming from the floor or the brake pedal?
Old Aug 18, 2011 | 02:22 PM
nagetech's Avatar
nagetech
Foot...whatever is clunking down there causes a vibration that is felt on the floor!
Based on the possiblites that you listed, how would wet days silence them?
Old Aug 18, 2011 | 02:25 PM
alloro's Avatar
alloro
Water is a temporary lubricant. Ever go down a pool slide or stand in a bathtub when it's dry versus when it's wet? Water can have the same lubricating effect on metal parts under a vehicle.
nagetech's Avatar
nagetech
Just to make sure I was clear on something..This problem happens in 2wd... Dont want you guys to think I meant it only happens when engaged in 4wd
Old Aug 18, 2011 | 02:26 PM
nagetech's Avatar
nagetech
I would guess then the differential couldn't be a culprit..as that is sealed and water shouldn't get in there to "lubricate" anything right?
Staytuned25
May 8, 2024 03:33 PM
5walleyes
Mar 14, 2014 10:36 PM
4x484150
1983 - 2012 Ranger & B-Series
Mar 1, 2013 06:17 PM
jblueguy
1997 - 2003 F150
Jan 30, 2013 06:56 AM
jboard
Dec 22, 2005 05:53 PM
