Horn doesn't work (but CC does)...
Old Aug 18, 2011 | 09:45 AM
ivory-tower's Avatar
ivory-tower
Just bought a 2005 Excursion, and the horn does not work. I've scoured the forum here, and while this is oft-reported, it is usually accompanied by the cruise control also not working. For me, the cruise control works fine, just no horn. The horn also does not "chirp" when I hit lock on the fob twice (it should).
Suspect a bad connection to the horn, or a burnt out horn, but I'm not sure how to diagnose it...
Old Aug 18, 2011 | 03:01 PM
BassFantasizer's Avatar
BassFantasizer
Test that you get power to the horns.
Pull the plug from the horns, hook up your volt meter, and had someone lay on the horn. If you get 12+ volts, the horns are dead. If not, you've got a break in the circuit somewhere.
Old Aug 22, 2011 | 07:58 AM
ivory-tower
Still trying to find access to the damn horns, without pulling the battery... They're supposedly under the "fender apron". Do I access that through the wheel well (i.e. behind and above the wheel), and if so how? I don't see any bolts in there that I can remove, just some rubber cladding, and not sure how I would pull it... Or do I access it from the engine compartment somehow?
I can hear a kinda clunking noise from the general area where the horn should be when I (have my son) hit the horn, or when I double-tap the lock button on the fob, which sounds to me like power is getting to the horn, but the horn is just burnt out. Unless there's some relay associated with the horn, and that's what I'm hearing...
Old Aug 22, 2011 | 10:51 AM
VR6Nutt's Avatar
VR6Nutt
Off topic, but the first thing that ran through my mind when reading the title of this thread was "Horn broken, watch for finger" - sorry had to share. :P
Old Aug 22, 2011 | 07:26 PM
Sheryle's Avatar
Sheryle
Horns
Just pull the inner fender. Not very hard, just note different size bolt locations.
GlueGuy
2015 - 2020 F150
23
Feb 20, 2017 04:12 PM
jim collins
Nov 8, 2010 01:40 PM
mordecai22
2004 - 2008 F150
Sep 5, 2008 08:06 AM
Northguy
1997 - 2003 F150
20
Jan 5, 2005 05:36 PM
rjjr38
Jan 27, 2003 11:29 AM
