Radiator Support
Old Aug 16, 2011 | 07:50 PM
Dylanpan214's Avatar
Dylanpan214
Radiator Support
Hey, i've been looking for a radiator support for my 66 F100, most of the radiator supports on Ebay usually go for 400 and then has 400$ shipping on top of that and im on a budget since im only 17 and i dont have a lot of money.
I found a 64 Radiator support that i could afford and also has reasonable shipping prices on Dennis Carpenter's Site and we called they said it would work with the 66, just some cutting involved thats it. So then my dad called them and ready to order it, the company said they havent had this in stock for over a year
After looking in LMC, Ebay, Dennis Carpenter, Craigslist, i've exhausted my resources for that one specific part and now im asking everyone here if they know any good AFFORDABLE sources for a 61-66 radiator Support, i only have about 400 to spend. Help is very appreciated, thanks.
Old Aug 16, 2011 | 08:41 PM
camperspecial65's Avatar
camperspecial65
welcome to FTE...
There were 3 different core supports used in the 61-66 body style...one that fits all 61-64, 65 4WD and 66 F250 4WD, 65 and 66 F350
the second fits 65 F100/250 2WD
The third fits 66 F1002 AND 4WD and 66 F250 2WD
the 61-4, etc also was used on some medium duty trucks and busses...but to keep it simple I intentionally left them out as those are fewer and further between then F100-350 trucks.
As to the price...they are a tough find...if yours is repairable I would look into that avenue...400 is about the going rate typically in wrecking yards as they are usually rusted out in most areas of the US except the desert areas typically...but there are exceptions...
- cs65
post some pics if you can of the rust/rot to see what you have relating to the core support.
Old Aug 16, 2011 | 09:26 PM
gangstakr's Avatar
gangstakr
I've got two of these left:
They are used, with no rust.
C2TZ16138G = 1961/64 F100/250 2WD/4WD / 1961/66 F350/600 / 1965 F100/250 4WD / 1966 F250 4WD.
If interested send me a P.M.
Old Aug 17, 2011 | 07:07 PM
ddavidv's Avatar
ddavidv
Have you tried the other truck vendors like Carolina Classics, Flashback F100's, National Parts Depot, etc for the repro support? I had not heard of them being on backorder.
If you get a 61-64 support, here's a how-to to make it work in a 'newer' truck: https://www.ford-trucks.com/forums/1...or-66-use.html
Old Aug 18, 2011 | 03:34 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Don, your applications for the 'second' & 'third' core (radiator) supports are amiss. Here's all the applications for the three puppies:
Reproduced: C2TZ-16138-G = 1961/64 F100/250 2WD/4WD / 1961/66 F350/600 / 1961/66 B500/600 (B = School Bus) / 1965 F100/250 4WD / 1966 F250 4WD.
Not reproduced: C6TZ-16138-B = 1966 F100/250 2WD.
Not reproduced: C6TZ-16138-C = 1965 F100/250 2WD / 1966 F100 4WD.
Old Aug 18, 2011 | 05:48 AM
oz 66's Avatar
oz 66
I got a repro from NPD and with modification it works.
As I have no chance of getting a good used part these are the only option, they are probably the better way to go imho as the originals were pretty rough anyway.
Old Aug 23, 2011 | 11:38 PM
thorswhisper's Avatar
thorswhisper
Repair it
I agonized with this same delima. After considering all the options, I decided to just repair mine. 2"X1" tubing and a little extra sheet metal and its stronger than new.
66with352
Apr 13, 2016 09:16 PM
kylejhowe
Aug 25, 2010 07:41 PM
doc66
20
Apr 10, 2009 07:01 AM
xlttruck
17
Dec 22, 2008 09:50 AM
fordtruck44
Aug 13, 2008 06:55 PM
