First ever truck pull
Old Aug 17, 2011 | 07:31 PM
  #31
turbohunter's Avatar
turbohunter
Originally Posted by cabloom300
i got the motor in hours before the pull.
Nice break in procedure
Old Aug 17, 2011 | 08:11 PM
  #32
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Hell Yeah!!! Love it!
Josh
Old Aug 17, 2011 | 08:21 PM
  #33
Rojak's Avatar
Rojak
Thanks for the info. I think I'll look for some pulls here in Central I'll and check it out.
Old Aug 17, 2011 | 08:55 PM
  #34
73 ford guy's Avatar
73 ford guy
Awesome video! Looked good. Hey what did you end up doing for the ujoint fix?
Old Aug 17, 2011 | 09:41 PM
  #35
cabloom300's Avatar
cabloom300
Nothing yet, i can find the Xcase yoke readily available and its good u asked because i was gona ask you about the slip yoke side. I found a 1350 on an older 3500 GMC, i have yet to get it off the driveshaft to verify the spline count but i can already tell its about 1.5 inches longer than the stock slip yoke, i know this isnt ideal but i didnt know if it would work or not, i know it would be pushed back pretty far but wasent sure if it was doable.
Old Aug 17, 2011 | 09:43 PM
  #36
cabloom300's Avatar
cabloom300
The motor had about 2 hours on the test stand before the pull, so it was plenty enough break in before it got ran full out.
Old Aug 17, 2011 | 10:09 PM
  #37
73 ford guy
It should be ok as that shaft doesn't really need slip travel. Maybe a tiny tiny bit just for vibration or flex of tcase on bushings which should be minimal anyway and you should use a t case brace. Worse case if it doesn't work cut the new slip yoke down(if needed) and it will still work except you will lose the threaded cap which isn't really necessary on that shaft again as it doesn't need slip and the threaded cap only holds in grease.
May have to use a small file to clean splines if you cut it.
Old Aug 17, 2011 | 10:13 PM
  #38
73 ford guy
Honestly I'm afraid to do burnouts in my stock f250 1 ton 4x4 with 31" tires. I feel more comfortable spinning my 44's with all 1350 joints, trac bar, 5:13's in a locked Dana 70 on my big truck.
Old Aug 17, 2011 | 10:27 PM
  #39
cabloom300's Avatar
cabloom300
Thanks for the reply, thats what i was thinking of doing if it indeed was to long, and i do plan on building a transfer case brace once time allows, i now started my Jr year of college so i only get time to wrench on the weekends. And now that im thinking of it, can you get the 1350 yokes for the rear end (D60) and the front (D44) used off something else? I dont want to put a ton of money into buying them new so im thinking of at least upgrading to sealed Spicers everywhere else because i may upgrade my rear end at some point and dont want to have to get a new yoke for that as well.
Old Aug 17, 2011 | 11:02 PM
  #40
tbear853's Avatar
tbear853
cabloom300 ... Fantastic first for you, and others are right, that 390 was putting the sounds out along with the ponies! Looks like you had a blast!
Bootlegger's Deluxe
72
Sep 24, 2025 12:28 PM
tbirdscott
22
Aug 28, 2015 12:51 PM
candoo
Jul 6, 2015 08:44 AM
rideracelivemx7
Feb 25, 2011 02:51 PM
Still Smoking
2004 - 2008 F150
15
Aug 20, 2008 04:09 PM
