hello all i have a problem or what i think is a problem with my new guage. i drove for 20-30 miles empty so far all at once and the guage reads only 110-120 degrees does that seem right. half at 35-45mph other half at 55-60 mph does that seem right or is the sensor not right on a 70 degree day. i have a new transmission with 8000miles on it with mercon v a upgraded oem 7.3l cooler little bigger than what came in it and had to get it for fords warrenty and a aftermarket derale inline cooler. it just doesnt ssem right seems really cold to me and the stock guage reads normal fast like 3 miles but that doesnt help cus there crap. what do you all think?
Once you added that Derale inline cooler to the mix you are going to see even more of a reduced temps in your tranny. On 90* plus degree days running at operating temps I've never seen above 150*-160*. Sounds good here..
That is great information! I knew the stock gauge was doing "that", because towing a 15K trailer up a 7% grade at 7,000', at about 80 degrees outside, it never moved above "normal". So I bought gauges and low and behold, it showed the temp going up to 220. So I added an additional cooler and changed fluids. No problems now, but relying on the stock gauge could cause you trans problems for sure, especially if your pulling!
I wish I could remember where I saw a chart that showed you what happens to the life of your trans fluid as you get to 200. All I remember is you don't want to be there.
Reason: spelling
Don't bother with that chart. It's a flat out lie.
