let’s say that’s exactly what is happening. How might I find that leak?
Originally Posted by BigAlsPSD
Are you sure your rear main is leaking? They are not that common...The valley drains at the passenger's side rear of the engine and drips down the bellhousing if you have leaks up top.
Welcome to FTE, Jphelps. Clean everything down with some simple green and start it up and see where your leak is coming from. It would be better if you start your own thread with a title that indicates your problem and tell us what your symptoms are. Many guys will pass over an older thread.
Below is a visual aid of the valley drain (under the turbo toward the firewall on passenger side) that often leads people to misdiagnose a simple oil leak as a rear main seal failure:
