Rear main leak
Old Apr 26, 2005 | 11:55 PM
toyrobotus's Avatar
toyrobotus
Rear main leak
Rear main seal on 87 6.9. Is it possible to replace it from the rear of the engine without dropping the oil pan completely? I have the cab off the truck and the bellhousing off so I have plenty of access to the rear of the motor. Do you just pull the plate off the back and replace it? Any tricks? Thanks
Old Apr 27, 2005 | 12:37 AM
PLC7.3's Avatar
PLC7.3
Get the Ford kit and it comes with a speedy sleeve, rear seal and installation tool, no need to disturb the pan at all unless leaking somewhere. You will need to get specific (permatex aviation #3) sealant required to seal flywheel bolt threads and Sp Slv, R seal to cover space.
Old Apr 28, 2005 | 11:42 PM
fordmudrunner2020's Avatar
fordmudrunner2020
Just finished doing it and it was a major pain in the but. Even though I had the ford kit the tool couldn't get it to go in straight so I ended up putting it in with a small rubber mallet. Just right before it is in get the tool to put it on the rest of the way.
