truck id prob
Old Aug 10, 2011 | 09:23 AM
mcmavv's Avatar
mcmavv
truck id prob
got a ford truck out of a bush,has an fe,says 390 2v on the breather but i think its a 360.question is ive got no title and the cab i.d says its a 78.anyplace else on the frame where vin might be.got it running and have a spare 'real' 390.and the truck is an f 100/150 4x4.thanks,first post btw
Old Aug 10, 2011 | 10:41 AM
Mauch1's Avatar
Mauch1
There should be a VIN plate on the drivers door or on the door frame. Ive also read of the VIN being stamped on a couple different spots on the frame itself, one spot being kind of below the alternater. Other spot im not sure of. But if you find it you can use this site to decode it: Decoding '73-'79 Ford Truck VIN Tags - FORDification.net
As for IDing the engine at a glance, there is no real good way of telling the differance between a 390 and a 360 just by looking at it. Best way would be to use the wood dowel trick and measure the stroke without having to tear the engine apart.
Old Aug 10, 2011 | 12:14 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The VIN is stamped on the frame in two places. The first, the one that you can see, is on the top right (passenger) side frame rail. It can be anywhere between the radiator support and firewall but is, as Mauch1 said, most commonly inline with the alternator.
It can be lightly stamped and be difficult to find/see.
The second hidden VIN is also on the top right frame rail, located under the cab, usually about 8-12" behind the front cab mount.
Old Aug 10, 2011 | 03:41 PM
mcmavv's Avatar
mcmavv
thnx guys,ill be lookin tomorrow
TRUBLU77
15
Sep 11, 2015 07:08 AM
Melbatoast
Mar 17, 2011 07:40 AM
skeelo
20
Oct 18, 2010 08:45 PM
lefty rodan
Jul 2, 2010 03:30 PM
mustangadam
Mar 16, 2005 01:01 AM
