0603 code
Old Aug 7, 2011 | 08:31 PM
Seth Hebert's Avatar
Seth Hebert
0603 code
2002 7.3 starts, run rough then clearsup after a few minutes, goes for sbout 4 to 5 miles then dies like i would have turned the key off, will not start, just turns over, if i wait until it cools it will start then do the same thing. 0603 code comes up. any one familiar with this?
Old Aug 7, 2011 | 08:33 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
"P0603 PCM has Experienced Power Interrupt."
Old Aug 7, 2011 | 08:44 PM
Seth Hebert
wats the pcm?
Old Aug 7, 2011 | 08:45 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Powertrain Control Module. Its the brains of the truck.
This can be caused by replacing your batteries, or installing a chip or tuner into your truck.
Old Aug 7, 2011 | 08:48 PM
Seth Hebert
so whats the next step u thunk i should take? Thanks
Old Aug 7, 2011 | 08:49 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Do you have a chip installed?
Old Aug 7, 2011 | 08:51 PM
Seth Hebert
yes. a powerpup
Old Aug 7, 2011 | 08:53 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
yes. a powerpup
P0603 is the code that says your PCM was modified with, usually by a chip. Its nothing to be worried about.
It is unrelated to how your truck is acting. Until you figure out what is wrong I would uninstall the chip.
I would suggest replacing your CPS (Camshaft Position Sensor)
Could be the ICP sensor as well. Just unplug, look for oil on it, if its oily, its failing. Can run with it unplugged to test as well, it will use default tables when unplugged.
Old Aug 7, 2011 | 09:05 PM
Seth Hebert
where is the icp sensor?
bigdaddys99
Aug 17, 2010 10:47 PM
RDC F250 7.3
Oct 8, 2007 10:00 AM
jsrdaily
Jun 1, 2007 11:00 PM
cdiddy
Oct 11, 2006 11:09 PM
dsldandually
Feb 2, 2006 06:31 AM
