Tip for RiffRaffs' FRX install...
Old Aug 7, 2011 | 06:08 PM
schlepprock250's Avatar
schlepprock250
It might've been said but I thought I would share my findings.I got an FRX from Clay at RRE this year,but after looking at the plugs and what could be involved in the install I decided to wait till I got home to do it.I've heard some guys say to use vise grips,7mm open end wrench,and a couple other ways to remove the plugs in the fuel rails,but I found that a 1/4in drive,"8point" 5/16 socket,8" extension and a swivel worked perfect,it didn't slip and I didn't have to use any PB Blaster...again,I just thought I would share....Phil
Old Aug 7, 2011 | 06:46 PM
bulla's Avatar
bulla
Thanks
For that Phil! Glad you got it. Good thing we stopped when we did.
Old Aug 7, 2011 | 06:49 PM
F-250 Super Duty's Avatar
F-250 Super Duty
Originally Posted by bulla
Thanks
Why stop then? Then it would turn into one of my stories!
Old Aug 7, 2011 | 08:07 PM
schlepprock250
I am running in to an issue though,when I installed the boss fittings in the heads,they didn't seat down all the way,they didn't "bottom out",are they supposed to?...anybody..
Old Aug 7, 2011 | 08:20 PM
mueckster's Avatar
mueckster
They are 1/8" NPT (tapered thread) and should not be bottomed out to be tight.
Old Aug 7, 2011 | 08:23 PM
schlepprock250
Thanks Roland,does about 1/2 way down sound right,it seems they would go a little lower,they got tight pretty quick,but I know the thread sealant has a little to do with that,but appreciate the thoughts...
Old Aug 7, 2011 | 08:28 PM
mueckster's Avatar
mueckster
Sounds like your good, Phil.
Old Aug 7, 2011 | 08:31 PM
schlepprock250
Thanks,I guess I'll just button it all up and check for leaks,I was scared to wrench on the bosses too much,I remember Cory telling me a story about one stripping out...I'll post back in a while though.
Old Aug 7, 2011 | 09:15 PM
schlepprock250
OK,I've got her idleing and have double checked and there are no leaks,I was just paranoid about the fittings not going down into the head any farther,but all is well...
Old Aug 7, 2011 | 09:16 PM
mueckster's Avatar
mueckster
Good job. Phil!
Old Aug 7, 2011 | 09:23 PM
schlepprock250
Well,I went to Clays site and read the instructions(after I started the work...OCD at its best),and noticed that the info about the 5/16 "8point" socket is posted in the "how to" section covering the FRX...Oh well...
deerslayer165
18
Apr 21, 2014 06:53 PM
a lincoln or two
Jun 12, 2012 04:13 AM
Mike F250
Aug 10, 2011 01:50 PM
emtmike
1997 - 2003 F150
May 28, 2007 03:43 PM
kevinken
1978 - 1996 Big Bronco
Mar 30, 2003 01:38 AM
