Light Frame Rust
Old Aug 4, 2011 | 06:29 PM
majohnson's Avatar
majohnson
8th Gear
Light Frame Rust
My 04 EX is showing some frame rust after being in Colorado for almost 4 years. I brought it with me to Colorado when I relocated from Southern California, so I could be close to family.
I did a search on the subject, coming up with the idea of spraying with used engine oil out of diesel. I have also seem a couple of different paint methods to deal with the rust. I stopped by my local body shop, the only solution there was separating body and frame to strip and repaint. The quote was rough for $4k could be more or less.
I could use some advise, cause right now its looking like time to sell before it becomes a real issue.
Old Aug 4, 2011 | 09:16 PM
airjeff's Avatar
airjeff
When you say light frame rust, can you describe it more? Seems a little drastic to sell, most vehicles around here have way more than a light frame rust and they don't have any issues. Unless the issue you are refering to is how ugly rust looks, that is very true.
Old Aug 4, 2011 | 09:23 PM
EXv10's Avatar
EXv10
Got pictures?
Old Aug 4, 2011 | 11:53 PM
wpnaes's Avatar
wpnaes
$4K? Nah, just do the oil spray once or twice a year and pocket the difference. You'll have the nicest frame So Cal and a typical, stained driveway - with matching earthquake cracks. Or park in the street to make that city asphalt last longer.
Old Aug 6, 2011 | 04:33 PM
majohnson's Avatar
majohnson
8th Gear
Rust
I brought the truck here from CA, what a mistake. The oil trick won't do well here. My place is 4 yrs old and not a spot on the driveway. Anyone tried the Chassis Saver product?
Old Aug 6, 2011 | 06:17 PM
njneer1's Avatar
njneer1
Don't sell the truck over a little frame rust
Old Aug 6, 2011 | 07:40 PM
wpnaes's Avatar
wpnaes
I say wire brush off the worst rust, paint brush on some of that rust converter, then paint/undercoat it the color of your choice. I'll be good as new. And pocket the $3969. If you want to get ****, mask off the brake/fuel/AC/etc lines before coating. Untreated, your truck will take 20+yrs in the salt belt to rust through a cross member.
Old Aug 7, 2011 | 08:49 AM
Snowseeker's Avatar
Snowseeker
I lay down a plastic tarp when I spray my frames and then let the vehicle sit for a couple days to drip off. After that one camping trip at highway speeds blows off any extra and it is all good after that.
Before spraying I used to brush the oil on.
Old Aug 7, 2011 | 08:50 AM
airjeff's Avatar
airjeff
What he said ^^, either find a place that specializes in rust proofing/treating cars or forget about it and enjoy the Ex.
Old Aug 7, 2011 | 09:02 AM
njneer1's Avatar
njneer1
Do you just use a garden sprayer ??
Old Aug 7, 2011 | 09:05 AM
Snowseeker's Avatar
Snowseeker
I use a cheap $20 body paint sprayer from fleet farm. It has a very big nozzle on it, I think stock, and flows well.
Old Aug 7, 2011 | 09:42 AM
njneer1's Avatar
njneer1
Just straight used diesel oil out of your Ex ? Do you add anything to it.....I've heard some people mix in marvel mystery oil with it
Old Aug 7, 2011 | 09:47 AM
Snowseeker's Avatar
Snowseeker
Just strait. I do all the oil changes on all the diesels and vehicles around here so I always save the best (blackest oldest) stuff I can get.
Old Aug 7, 2011 | 09:55 AM
njneer1's Avatar
njneer1
Thanks ! change my own too...at $100 for Rotella full synthetic and a Motorcraft PSD filter..... I couln't afford to let anyone else do it.....plus I don't trust them.....I want to know it's right
Old Aug 7, 2011 | 05:30 PM
saz2686's Avatar
saz2686
I painted my Excursion with chassis saver. Here is a thread https://www.ford-trucks.com/forums/9...l#post10129702. Update - it is still holding up well. This fall I plan on powerwashing and touching up or maybe another full coat for the heck of it. It takes a while but worth it. Depends on how much effort you are willing to put into it
Country705
Jun 24, 2008 06:38 AM
kkester
1983 - 2012 Ranger & B-Series
Dec 29, 2006 01:52 AM
mjbesen310
2004 - 2008 F150
Dec 28, 2004 09:03 PM
scottsheppard
Paint & Bodywork
15
Aug 30, 2004 02:24 PM
afinepoint
Paint & Bodywork
Jan 15, 2004 12:27 AM
