How do you handle rusted Frame??
Old May 16, 2004 | 07:28 PM
scottsheppard's Avatar
scottsheppard
Hello Folks,
I have a 1978 F250 4X4...It has been ib the family a lomg time and will be a lot more if I can help it. The frame is really bubbling with rust underneath...when you dig into the paint you at times get 1/8 " rust with it. The frame is still ok but I need to know how to treat it. Correct me if I am wrong, but my plan is to scrape the rust etc off and dig down to good metal--after that I plan to oil coat the the frame at a local rust doctor kind of place...How does this sound to you guys??
Appreciate your help.
scott
Old May 17, 2004 | 12:35 AM
Aekisu's Avatar
Aekisu
<cr>
After getting the loose rust off, personally I would use Zero Rust. Besides being available in a rattle can, it stops the rust dead, and it has what I consider the perfect semi-gloss for a frame.
Old May 17, 2004 | 01:42 AM
AK4Wheeler's Avatar
AK4Wheeler
I did alot of research and talked to a lot of people who restore vehicles and I found that most prefer to use POR 15 for killing present and future rust.
I just finished doing the frame on my 78 F-250 4x4 and I like the way it turned out.
Old May 17, 2004 | 07:01 AM
Huntsman's Avatar
Huntsman
I did my frame with POR-15 a couple of years ago but have since started using Zero-Rust based on what I have read here and elsewhere. It’s about have the price and a lot healthier to work with. Both do a good job and look identical when finished.
Old May 17, 2004 | 11:57 AM
scottsheppard
Thank you guys...Zero Rust sound really good...do you oil coat after that or is it not required?
scott
Old May 17, 2004 | 03:00 PM
Carlene's Avatar
Carlene
Admom
No need to oil coat. ZR & POR are both paints that dry to a nice gloss finish.
I think you can get them in a flat finish also, but not sure. I like the gloss on the frame.
Old May 17, 2004 | 09:52 PM
DeckedoutF150's Avatar
DeckedoutF150
where can you get the zero rust from??
Old May 18, 2004 | 12:39 PM
Aekisu's Avatar
Aekisu
Well, you can buy it from Eastwood. Another options is to stop in at the ZR web site and ask them. They should be able to direct you to a local seller.
Old May 18, 2004 | 03:44 PM
DeckedoutF150
thanks for the info
Old Aug 19, 2004 | 08:09 AM
black460's Avatar
black460
is rust bullet better then zero rust....probably personal preference?
Old Aug 19, 2004 | 11:05 PM
Aekisu's Avatar
Aekisu
<cr>
Don't know. I do know ZR performs better than POR15.
Old Aug 23, 2004 | 10:20 PM
subcoolman's Avatar
subcoolman
Just a thought here-
My neighbor is a bowtie kinda-guy, but other than that he's ok. He recently rebuilt his ride (frame-off resto), and he had the entire frame Rhyno coated. Tough as hell and warranteed forever. Looks pretty cool, and his truck will probably be around a long, long time.
Old Aug 24, 2004 | 04:33 PM
DeckedoutF150
i would have the frame and under the body coated in that.
Old Aug 30, 2004 | 09:18 AM
Gobstopper909's Avatar
Gobstopper909
i was thinking about cleaning my frame up and makin it purty underneath. if i was going to use zero rust, how would i prep the surface? just scrape the surface rust off with a wire brush or get a wire wheel and take it down until its shiny?
Old Aug 30, 2004 | 09:54 AM
bigbronco88's Avatar
bigbronco88
i was wondering the same thing .but im thinking power wash the under side and wire brush and wire wheel it .....and goggles!
if i am wrong i hope someone can help us out
