Ignition Switch problem
Old Aug 4, 2011 | 05:13 PM
teppler's Avatar
teppler
2005 6.0, diesel XLT, Last week I stopped the truck shut off ignition and pulled the key, when I opened door the buzzer went off like the key was still in the ignition, I wiggled switch without key in it and it stopped but will start again if I wiggle it. is it the lock mechanism or the ignition switch itself? How hard is it to replace?
Old Aug 4, 2011 | 05:58 PM
william_04_x's Avatar
william_04_x
There's a set of contacts in there that may be getting worn/loose. The good part is they are on the outside of the ignition switch assy. To remove the switch you need a skinny allen wrench( 1 or 1.5 mm) . Look up at the bottom of the steering column and you'll see holes for the screws that hold the column trim together, and one under the ignition switch. Turn the key to run, press the allen wrench firmly up into the hole under the switch, and pull the switch straight out. Look around the outside of it and you'll see a set of exposed electrical contacts. You can either open them up a hair, or put a small piece of electrical tape between them so the dinger doesn't go off when you have the door open and key in the ignition. Slide the switch back into the column when you're done. I did this years ago because I'm always tinkering on the truck with the key in and door open, and that noise drove me nuts.
Old Aug 4, 2011 | 06:01 PM
william_04_x
FWIW: It's easy enough to pull that I went and got mine out to grab a pic for ya.
Old Aug 4, 2011 | 06:25 PM
BLADE35's Avatar
BLADE35
great pics william
learned something new today
Old Aug 4, 2011 | 06:31 PM
william_04_x
Thanks Benny. That mod is definitely worth more than the piece of tape it takes to perform it.
Old Aug 4, 2011 | 09:49 PM
johnthoms's Avatar
johnthoms
At last I can silence that chime, it's been driving me nuts since I bought truck new (06) . Simple, easy , quick thank you thank you my heads stopped dinging
Old Aug 4, 2011 | 10:01 PM
bismic's Avatar
bismic
Definitley a great mod! It was one of my early ones as well. Thanks for the posts William - reps coming your way as soon as I can again.
Old Aug 4, 2011 | 10:03 PM
teppler's Avatar
teppler
I just love this Forum..thanks a million.
Old Aug 4, 2011 | 11:06 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Well you got me there Mark. I haven't done this one yet.
So, that just pulls right out? So easy, that you can just run out and snap a picture? Really!
Would this prevent theft of the truck?
Sent reps His way!
Old Aug 5, 2011 | 01:54 AM
bismic's Avatar
bismic
Yeah - removing the ignition would be a decent theft detererent - at least for the "not too diligent" criminals! It is certainly easy to do.
loganmick
16
Jul 11, 2015 05:09 PM
dyoungen
Dec 24, 2014 09:53 PM
bigblockford_390
Nov 4, 2011 11:26 PM
jrv
May 16, 2008 08:49 PM
jeff_67cougar
Aerostar
Sep 9, 2002 06:03 AM
