Column ignition key switch removel
Received 3,103 Likes
on
Can't get the cylinder out.
I got the same info from many people including the dealership. "Put in run, push the pin that goes thru the housing and the key cylinder will slip out." WRONG!! I tried that and it refused to "slip out". Ended up prying it out and broke the end off the cylinder. Looked closer and saw a circlip at the bottom holding a washer in. Got the circlip out and the washer, with a notch to line up the cylinder fell out. I ended up putting the part that broke from the cylinder in a vice and prying the gear off of it. After I cleaned it up I pushed the new cylinder in and then pushed the pin and yes it came right out. As for the pot metal linkage, I saw a guy on "youtube" that ground his pot metal linkage so he could put it in without taking everything apart. I tried it and yes it did work. Takes time but it was worth that instead of taking the whole thing apart like I did years ago. Just go slow if you do it. I work as a machinist so it wasn't anything I hadn't done before.
kevinfromwebb
11-24-2018 06:02 AM
campbells111
02-06-2009 12:00 PM
89f150mike
06-11-2006 10:02 AM
