My motor rebuild/replace thread
Old Aug 10, 2011 | 08:21 AM
jt371's Avatar
jt371
______
Ok, so my motor was probably never opened until I started on it. I plan to use whatever is required to do it right. Thanks.
Old Aug 10, 2011 | 08:49 AM
megawatt00's Avatar
megawatt00
I am still in amazement from when you sent me the pics last night. As much as this is not good for you it is a testamant of the toughness of the 7.3 to keep running!
Old Aug 10, 2011 | 06:39 PM
jt371's Avatar
jt371
______
Checked ring gap on a used top ring and it was 0.018 gap. Still within spec. My cousin came over with bore gauge and found cylinders are 0.001 out of round.
Old Aug 14, 2011 | 08:01 AM
jt371's Avatar
jt371
______
Anybody have any ideas how/why a piston skirt would/can break?
Old Aug 14, 2011 | 03:59 PM
94 smokin stroker's Avatar
94 smokin stroker
Hey jt371 here is a thread that should help you out tons if you cant find what you need in it ask pm cory nobody i would trust more on knowing the tolerances and what is ok to do https://www.ford-trucks.com/forums/1...tor-build.html
Old Aug 14, 2011 | 04:08 PM
jt371's Avatar
jt371
______
Thanks. I did finish reading that thread the other day. I found a service manual for the 7.3 online. I downloaded it. It has all the torque specs and tolerances.
Old Aug 14, 2011 | 04:22 PM
ChunderDownUnder's Avatar
ChunderDownUnder
There is a great list of PDF manuals here
Workshop Manuals - 1999 SD 250-550 - PowerStrokeNation
I think its page on the engine pdf that has all your measurement specs.
Those bearings look fine compared to mine
https://www.ford-trucks.com/forums/1...r-build-2.html
Old Aug 14, 2011 | 04:46 PM
jt371's Avatar
jt371
______
That is the manual I downloaded and yes it does have the specs. Thanks for the list of the other manuals. Ill download them tomorrow when I get to a computer.
Old Aug 15, 2011 | 08:06 AM
jt371's Avatar
jt371
______
Well spent most of yesterday cleaning some parts. After removing the engine I found that my oil pan had quite a bit of rust on it. So I cleaned, primed and painted it. Then I deceided to paint a couple other things.
Old Aug 15, 2011 | 08:28 AM
bulla's Avatar
bulla
Nice! I like following these rebuild threads. Soon enough I'll feel confident enough to tackle my own!
Old Aug 15, 2011 | 04:12 PM
garsm's Avatar
garsm
just pulled me engine yestereday too due to low compression, im going out now to tear the internals down. ARe you planning on doing a rebuild kit? And what upgrades are you doing while the engine is out?
Old Aug 15, 2011 | 04:19 PM
jt371's Avatar
jt371
______
I'm planning on doing a OEM rebuild kit. My cylinders checked out so no need to bore it. I'm going to install the bellowed up-pipes. Also going to rebuild the EBPV, turbo and install WW. I would like to install head studs but I have to draw the line somewhere, plus they can be installed later easily.
Old Aug 15, 2011 | 04:37 PM
  #28
Shake-N-Bake's Avatar
Shake-N-Bake
Originally Posted by jt371
Look what I found in the oil pickup. That is a chunk if piston. There was smaller pieces that fell out after I removed the pickup. Also a picture of what I found in the oil pan, a big piece of the piston. Also the crank bearings. They are in order. So I can see why my lead was high, missing some from the front bearing.
How high was the lead in your last sample? Did you post the lab report in another thread? Mostly curious to see how the reports looks considering the issues you actually discovered during the tear down.
Old Aug 15, 2011 | 04:50 PM
  #29
jt371's Avatar
jt371
______
Between my last two samples it went from 3 to 8ppm.
Old Aug 15, 2011 | 05:03 PM
  #30
Shake-N-Bake
Wow, that is surprising. A delta of 5 ppm is practically nothing. I was expecting you to say the lead was in the 80-200 ppm range.
Are all your piston cooling jets in place?
