1978 - 1996 Big Bronco
engine removal
Old Aug 3, 2011 | 12:35 AM
blkfordtruck's Avatar
blkfordtruck
engine removal
I recently bought a 1982 Bronco with a 351 W engine. The engine is locked up and I want to remove it for rebuild. I have top of engine torn down, heads removed. I have the bolts from the bell houseing and the engine mount bolts out as well as the starter removed.
I cannot get the flex plate bolts out ( it is auto trans. ) because the engine is locked so I can't turn the engine to get to the bolts. What kind of problem will I have getting the engine out?
Old Aug 3, 2011 | 05:27 AM
gjnicholas's Avatar
gjnicholas
if you pull the tranny out with it you then can seperate the tranny from motor leaving the TC hooked to the motor then you will be able to get to the bolts eaisly
Old Aug 3, 2011 | 11:52 PM
blkfordtruck
Don't want to take tranny out. Won't the coverter just slide off tranny with the engine?
Old Aug 4, 2011 | 04:49 AM
gjnicholas's Avatar
gjnicholas
it should if you have enough room in front to move that much or you can go just far enough to reach those hidden bolts
Old Aug 4, 2011 | 09:02 AM
Joseph69's Avatar
Joseph69
If you dont have the room for the converter to fit coming out, you might have to drop the crank out. But that can be hard to get off. You can also unbolt the cross member from the frame, pull the drive shafts and just slide the transmission and transfer case back a little while still bolted to the cross member. None of it will be easy.
Devane
1983 - 2012 Ranger & B-Series
Apr 29, 2013 03:45 PM
78BigBlock09
Apr 22, 2010 07:31 PM
ZombieSlayer
Aug 21, 2004 07:21 PM
wvmiller_68
Mar 16, 2003 11:16 AM
TheWiz427
Apr 29, 2002 10:01 AM
