Rounded Tranny Bolts
Old Apr 28, 2013 | 11:48 PM
Devane's Avatar
Devane
Exclamation Rounded Tranny Bolts
Ok so I am new here and have a few questions. i recently bought a 96 ranger 4wd that needs a new tranny. I have been reading and looking at several peoples threads that they have going on here and it has helped much in my efforts in removing a transmission however, i managed to round off the top bolts from the tranny to engine bolts.
these are the bolts at 1 top right and 3 the one behind the wire harness.
I have the truck up on jack stands high enough that i can sit under neath it and look down the transmission towards the engine and see the bolts.
I have tried using bolt extractor sockets, i rounded the internal teeth of the sockets.
I then upgrade to Grip-tite cam sockets and even these keep slipping.
I tried to get up in there with a dremel to add edges to it but dont have enough room to reach all the way. I cannot get a torch in there either or a drill.
Is there another tool that someone can recommend in getting rounded bolts or is there a way to undo the engine mounts so I can tip the tranny down farther to have more room to get a grinder or a drill in there?
any advice would be greatly appreciated!!!
thanks in advance.
Old Apr 29, 2013 | 08:05 AM
stuart1's Avatar
stuart1
Remove the cross member and lower the assembly.
Remove the transfer case.
That should give you lots of room.
By the sound of it you or somone had the wrong size socket.
Are the bolts imperial or metric?
Old Apr 29, 2013 | 10:01 AM
Devane's Avatar
Devane
I have the transfer case off and the crossmember as of right now my tranny is free hanging off the engine block. I have all but the 2 bolts left to be able to pull the tranny out.
Old Apr 29, 2013 | 10:15 AM
stuart1's Avatar
stuart1
You may have to use your dremel and cut the heads off.
Old Apr 29, 2013 | 10:21 AM
Devane's Avatar
Devane
Tried that too but can't get enough leverage on the dremel to cut through it. I even resorted to cutting a hole through the floor boards ad trying that way but the damn riveted heat shield is in the way
Old Apr 29, 2013 | 10:36 AM
stuart1's Avatar
stuart1
Can you drive a smaller socket onto the head?
Have you tried a wobble adapter?
Old Apr 29, 2013 | 10:39 AM
Devane's Avatar
Devane
By wobble adapter you mean for a socket yes I did. That's how it got rounded in the first place.
Hammering the next size socket down is the next option I had
Old Apr 29, 2013 | 03:45 PM
stuart1's Avatar
stuart1
I did not mean a universal socket.
Wobble adapter and universal socket are different animals.
roshan
Sep 3, 2013 08:46 AM
Greg5OH
May 16, 2012 11:33 AM
maldbwmjr
Sep 10, 2008 09:03 PM
khadma
Engine Swaps
Apr 10, 2007 10:45 PM
