engine bolts into bellhousing
Old Mar 16, 2003 | 02:54 AM
wvmiller_68's Avatar
wvmiller_68
I have a 68 f100 2wd the motor is supposed to be a 289 not the original went to unbolt tranny every engine ive ever seen bolts through tranny thread into engine block this one just the oposet bolts go through block thread into bellhousing just wondering if this is going to be a problem if i do a tranny swap any help would be appreciated.
Old Mar 16, 2003 | 10:23 AM
Mike W's Avatar
Mike W
I have never heard of such a thing. The bellhousing holes are not threaded. Did someone use smaller bolts with the head on the engine side? The top two are blind holes so you could not do that. Are there only 4 bolts holding the bellhousing on?
Old Mar 16, 2003 | 10:33 AM
sparky's Avatar
sparky
I am with Mike on this one I cant remember seeing any engine of any type that bolts to the tranny
Not saying it isnt so but I would guess it is a modification. Maybe someone tapped the tranny holes and drilled out the engine ones....but there are those blind holes in the engine block.
But people can be very resouceful if they put their mind to it
Old Mar 16, 2003 | 11:16 AM
8NRay's Avatar
8NRay
I've never seen such a thing either. My C6 for the 429 has one threaded bolt hole in the bell housing for one of the starter bolts.
