Sponsored by: Real Truck
450 fourwheel drive problem
Old Aug 1, 2011 | 07:07 PM
THEREBEL's Avatar
THEREBEL
Question 450 fourwheel drive problem
i have a 2008 ford 450 drw the 4wheeldrive high light comes on and off, truck will go in and out of high. got it in 4w high one time took 30 min. to get out. took to ford in va they reprogramed and said they couldnt find a problem for 89.00. got home to fla still having problem, ford in alachua checked no problem; no help. has anyone had this problem i pull a 37ft camper, any help would be appreciated.
Old Aug 2, 2011 | 10:54 AM
bpounds's Avatar
bpounds
Could you be a little more clear, please?
Does the 4WD light go on and off randomly all by itself? Or just when you turn the dial?
The one time it took 30 minutes to go back to 2WD, was the dash light on that whole time?
Old Aug 2, 2011 | 11:04 AM
F250Wheels's Avatar
F250Wheels
Are you shifting in and out of 4x4 while moving or sitting still?
I also have a 2008 F450 4X4, I always shift in and out of 4x4 while moving off the thottle.
Old Aug 3, 2011 | 07:18 PM
THEREBEL's Avatar
THEREBEL
going down the highway at 60mph light flasnes on and off , truck surgess trying to go into 4wheel high. if your in cruise control it cuts off about 10sec. before 4wheel light comes on and off. unplugged transfer case wire, 4wheel wont work but light doesn't come. hope to get it fixed if i can find out what the problem is. also if you turn the 4 wheel switch 4wheel works ok.
Old Aug 4, 2011 | 09:20 AM
bpounds's Avatar
bpounds
Okay, now I understand. Sounds like an intermittent electrical gremlin. You said you disconnected the shift motor wire and the problem went away, so I think it could be a bad shift motor. The motors have sensors inside that tell the computer that the shift is completed, and we are in 4-Hi or 4-Lo, or whatever. I'm thinking you are getting a false signal from a sensor inside the shift motor. The motor itself seems to work, since 4WD works when you want it to, but the sensors could still be sending false signals. I have no idea if that is something that can be disassembled and checked.
Old Aug 4, 2011 | 05:07 PM
THEREBEL's Avatar
THEREBEL
Smile
thanks for the input, now if i can get ford to fix it. thanks mac
Old Feb 7, 2012 | 01:32 PM
THEREBEL's Avatar
THEREBEL
have tried 4 ford dealers spent nearly 700.00, put truck into shop yesterday they called today said they cant find the problem. said they could start taking the front end apart to see if its in the four wheel drive system. cant afford much more. told them to disconext 4wheel i will go get truck. does anyone know anything else i can do or contact? help...
Old Feb 7, 2012 | 07:51 PM
galaxie641's Avatar
galaxie641
Seems to me it should be covered under the 5/60 or are you over on miles?
Old Feb 7, 2012 | 08:03 PM
Quad Racer's Avatar
Quad Racer
Could it be a bad switch? The one on the dash? Seems like it could be a cheap fix, but I dont know. When Im troubleshooting I usually start with the easiest component to fix/check. You know, with all the threads on this forum about the 4x4 system of these trucks acting up its a damn shame! Come on Ford,!!!!!!!! quit acting like Chev.
Old Feb 7, 2012 | 09:27 PM
Kajtek1's Avatar
Kajtek1
So the dealers charged you $700 trying to learn how to fix your truck? I would call regional representative and request assistance.
Dealer should find the problem or refund your money.
Old Feb 7, 2012 | 10:16 PM
Quad Racer's Avatar
Quad Racer
Yeah no kidding. If I dont fix it I dont charge my customers. $700 and no resolution? Thats B.S.
Old Feb 8, 2012 | 05:26 PM
THEREBEL's Avatar
THEREBEL
Cool 450 fourwhrrldrive problem
ford dealer cant find problem said they could pull front end apart to find problem but it would cost abunch. problem started at 53000 miles now over 61000 still same problem. what happened to ford tough?
DCPage
Apr 30, 2011 07:33 PM
MOOOOOPS
Sep 2, 2009 04:08 PM
Kuskoal
Jun 2, 2008 09:24 PM
chixon
Dec 6, 2003 01:06 PM
