Sponsored by: Real Truck
Will they fit?
Old Feb 8, 2012 | 03:04 PM
#LHB#'s Avatar
#LHB#
Will they fit?
Ok so went to get my tires balanced the other day and found out that i had 3 bent rims, i found a set of rims on craigslist that were 16.5x12. Will they fit on my stock 02 f250 with a set of 33x12.50 bfg at on them without any kind of lift? Im just looking for some replacement wheels as its just a work truck nothing more. Thanks
Old Feb 8, 2012 | 03:59 PM
dag5984's Avatar
dag5984
They will fit fine....unless offset is crazy
slammer's Avatar
slammer
I dont think they will work...SuperDuty bolt pattern is 8x170mm. I think the wheels you're looking at are pre- SuperDuty rims. I think they are 8 on 6.5. to be absolutely sure, measure between two holes across from each other. Should read 170 mm to work on your truck.
Old Feb 8, 2012 | 04:49 PM
akaFrankCastle's Avatar
akaFrankCastle
x2
Trying to find 8x170mm 16.5" wheels is a pain in the ***. I lucked out and found two separate Chebby owners who thought they would match their bolt pattern. Bad for them. Good for me.
Old Feb 8, 2012 | 05:37 PM
dag5984's Avatar
dag5984
Bolt pattern is key...there are 16.5 wheels out there...just sold a set last month...check the tech folder regarding wheel fitment....i am running 20x9 with 35-12.50 tireson my stock 2003
Kelly Aitken
29
Jan 24, 2017 08:35 PM
*2fords*
May 30, 2012 08:10 PM
mstiles19
Jul 26, 2010 03:02 PM
LWM97
Feb 8, 2005 09:10 PM
got2lb
Sep 16, 2004 08:45 PM
