hard to shift from park
Old Jul 19, 2011 | 08:11 AM
riverratba's Avatar
riverratba
2007 F150 supercrew, sometimes it doesn't want to shift out of park even on a flat surface where its not torque locked.. is there an adjustment i can do myself?
Old Jul 19, 2011 | 09:25 PM
Cofcmsc's Avatar
Cofcmsc
Is it tough to shift From Neutral to Park as when parked on a hill with no e-brake or will it not shift until you fiddle with it? If it is the latter I bet it is in the safety lock mechanism. I have heard of multiple problems like this on other vehicles usually Toyotas and Hondas and it was either the switch on the brake pedal or the actual electronic lock mechanism. Just ran out and checked mine. You should hear a strong and clear clicking in your column when you depress the brake. Unless you have center console shifting of course then I would think that you should still hear the click. Next time it sticks try tap dancing the brake pedal. BTW Those Toyotas and Hondas were center console shifters. My two cents. Good Luck! Shawn
Old Jul 20, 2011 | 07:19 AM
MCDavis's Avatar
MCDavis
As Shawn eluded to, it's likely the brake pedal switch.
RMeans
May 16, 2016 01:14 PM
tommyl
Dec 4, 2015 11:33 AM
jeremy2008
Dec 21, 2011 04:28 AM
iron1951
Feb 18, 2011 06:39 PM
benjh1028
Jun 1, 2003 07:23 PM
