Won't shift into park
Old Dec 3, 2015 | 11:37 AM
tommyl's Avatar
tommyl
Won't shift into park, Checked the two bolts and they were tight. Ended up having a rock wedged behind shift lever on the transmission. FYI.
Old Dec 3, 2015 | 01:35 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Those are the only two causes for not shifting into park that I've ever run into.
Old Dec 3, 2015 | 06:39 PM
holeshotwalt's Avatar
holeshotwalt
Had the same issue with the rock about 2 weeks after buying my X! Found it after searching on here.
That was my first 'Thanks to FTE'! Now I've had many...
Old Dec 4, 2015 | 11:33 AM
hotrodfeguy's Avatar
hotrodfeguy
I had a problem with the end of my cable last year. Had to use a zip tie to get me home. As it was off by half a gate on the indicator. Just would not quite go into Park. Zip tie got me home down on the end of the cable down on the shifting lever where it went into the trans. Until I could do a real fix. Look at that connection may have to have a helper move the shifter while you look.
mikey rojas
2004 - 2008 F150
Jun 1, 2018 02:39 PM
WADED13
2004 - 2008 F150
Nov 28, 2011 07:28 PM
LSO1123
Oct 9, 2011 05:00 PM
LUMBERMAN
Feb 22, 2010 11:31 PM
Totally Tuna
Nov 30, 2008 02:44 AM
