Check u hual parts.... A reman IP is 275 with no core new BB code injectors u can get for about 28 a piece from a diff website I'm on my bb not my PC or else I'd hook you up with the link
The fss will be on the reman pump, I would go with new injectors over reman thoughfor the minimal price diff. The fast idle solenoid does not affect how one runs.
I seem to remember some bad reviews on diesel care pumps, do a little research.
ordered injectors, IP and return line kit from Pensacola Diesel, should be here this afternoon. spent yesterday painting new bed and waited until I was done to think about B4 and after pics DOH!
Diesel Care messed up my order and sent me two return line kits instead of a pump install kit. They sent me a $24 part instead of an $8 part. Oh, well.
update, decided while I had the IP and lines out I might as well change Gps and clean everything up. so I shot degreaser all over and then rinsed it very carefully. when I went to change the Gps I discovered the wells they sit in were full of diesel jelly, baked on, bounce off the wall, and poke your eye out diesel jelly. I ended up scraping it out with a screwdriver, I could actually cut it into cubes and pop it out. cleaned out the drains as best I could and blew everything out w/compressed air. I took out the CDR, (original) cleaned it and stuck it back in.put lines on new IP after I hit them w/ flat black Hi temp paint. And then it started raining! I'll get back out this afternoon and try to get everything plugged in.Oh yeah had to get new fast idle solenoid from stealership $181 WTF
forgot to mention putting all new hoses on transmission cooler, new FSV and pickups in tanks
Reason: forgot sumpin
My high idle solenoid doesn't work, either. I was going to replace it but then I saw the price and said it will be a cold day in hell before I spend that much on a solenoid.
