stupid ? fuel pump
Old Jul 8, 2011 | 06:27 PM
Marianna2003's Avatar
Marianna2003
Originally Posted by starmilt
It also sounds like it tried to start to me.
If you do pull it off again, just make sure the arm is angled down when you slide the arm in . If the cam lobe is in the right place it will bolt up with no resistance, if not you will notice it trying to hold the pump at a slight angle.
Answer to diesel fuels question, there would not be enough difference to be noticed, but it does take power, not near as much as the alt, power steering, fan etc.
Hey Starmilt, I thought you fell off the face of the earth.
Hp=Pressure(PSI) * Volume(GPM)/1714 HP required to flow 1/2 pint in 10 seconds at 7 PSI or 0.00153HP. Assuming 100% frictional losses, that's only .003 HP to be gained by eliminating the Mechanical fuel pump.
Old Jul 8, 2011 | 06:30 PM
vfelix702's Avatar
vfelix702
Good way to answer that!!
Old Jul 8, 2011 | 08:00 PM
RA31925's Avatar
RA31925
Heh heh, that's my kind of answer, too.
And, I figured as much. Not much to be gained other than increased reliability.
Old Jul 10, 2011 | 10:59 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Originally Posted by PLC7.3
Did you install one of the new long arm lift pumps....... it should have come with a HOW TO sheet.......
WARNING
This fuel pump must be installed only at the low position of actuator cam.
If the pump is installed at any other position than low cam, the pump will be ruined, the engine will stall and damage may result.
Incorrect installation will loosen the pivot pin and allows the pin and lever to come out of the pump and drop into the oil pan. This can occur immediately or after several hundred miles. This type of failure is not covered by warranty.
To ensure that the cam is at low position, it is necessary to use a mirror and a remote starter switch. Observe the cam through the mounting port and bump the engine around until a one (1) inch wide machine surface is observed. This is low position of the cam. Now complete normal fuel pump installation.
using the search feature PRIOR to installing new idi parts is always a good idea.
had you searched,you may have found alternative solutions as well.
there ain't no rod on a block off plate.
Old Jul 10, 2011 | 04:58 PM
srqdiesel chef's Avatar
srqdiesel chef
ok, finally got back to work after 2 days rain, keep in mind I want a garage 4 my b-day.
So I tested fuel flow at the schrader valve and got 1/3 pint in about 8 seconds compared to 1/6 pt in 15 seconds b4. started cranking and got nothing, cracked a couple of injectors and cranked no bubbles and no start. completely disconnected 1st injector on drivers side engine and there is NO fuel coming out. WTF?
Old Jul 10, 2011 | 05:27 PM
vfelix702's Avatar
vfelix702
Make sure you have 12v going to the Fuel shut off Selinoid .... (FSS) any thing before as far as fuel just means the machanial side of the pump is working I.E. Pressure at schrader valve
Old Jul 10, 2011 | 06:53 PM
srqdiesel chef
got 11.45 volts at FSS is that close enough for government work?
Old Jul 10, 2011 | 07:04 PM
starmilt's Avatar
starmilt
Can you hear the fuel solenoid clicking. I have also had the ip's seem to air lock before too.
What were the symptoms that led up to you changing the lift pump.
Old Jul 10, 2011 | 07:09 PM
srqdiesel chef
truck ran like a tired dog, hard start, died when I let off throttle. so I ran some atf through to clean it and when that didn't work I check flow at the schrader and it was sloooow, checked lines for kinks and leaks and found nothing, RTFM and figured that I needed to change lift pump. spent $150 on oem shop manuals and so far they are worth it
Old Jul 10, 2011 | 07:11 PM
srqdiesel chef
should the solenoid click with key on engine off? and how do I make it click? just want to make sure I'm doing this right
Old Jul 10, 2011 | 07:15 PM
starmilt's Avatar
starmilt
Hopefully it was all in the lift pump. I sent you a pm, if I did it right.
Old Jul 10, 2011 | 07:18 PM
starmilt's Avatar
starmilt
It should click when you turn key on one time. The easiest way is to turn the key on and pull the wire off the pump, it should click when you reattach it, you can also leave the key off and use a jumper wire.
Old Jul 10, 2011 | 10:01 PM
  #28
eatont9999's Avatar
eatont9999
You will need to turn the key to the point where the glow plugs kick in if I recall correctly. Then you can test the FSS.
Old Jul 13, 2011 | 05:49 AM
  #29
srqdiesel chef
ok, the noob questions keep just coming. When I'm bleeding the system, I've been trying to bleed 2-3 injectors at once, I crack them, crank for 15-20 secs while I'm loosening them up a little more and then tighten them up after I stop cranking.then I do something else for a few minutes and let the starter cool down and start over. So, last night I was looking at the now wet injectors and realized that all the air I just bled out is getting sucked back in while I tighten them down, right? So instead of doing 2 or 3 I should do 1 at a time so I can tighten up on it while I'm cranking the engine to avoid sucking air back in, that way 1 line at a time will get bled completely and I can go on to the next one...right?or will doing 1 at a time just prolong a process that has already taken way too long? aaaaaaaaaaaaaaa
Old Jul 13, 2011 | 08:06 AM
  #30
tecgod13's Avatar
tecgod13
Unless I'm mistaken, there are check valves at the injection pump for each line. Besides that, the way the injection pump works, air can't leak back in from the injectors.
So you should be fine doing what you are doing.
