Front Hub Help
Old Jul 6, 2011 | 03:08 PM
Jeepers2003's Avatar
Jeepers2003
Front Hub Help
This week, while replacing the wheel studs on the front hub of my '76 4x4, I could not get the studs to seat properly. It seems as though the hub is trashed and needs replacing. The problem I'm having is that in trying to find new hubs online (searching for locking hub) I am only coming up with pages for the mechanical portion that one turns to lock in the front end.
Is there a different term for the piece that the wheel actually mounts to?
Old Jul 6, 2011 | 03:28 PM
ford1977owner's Avatar
ford1977owner
LMC Truck Parts - Page 133
hope this helps...
Old Jul 6, 2011 | 03:39 PM
wyckedcombo17's Avatar
wyckedcombo17
Is the hub actually trashed or just where the wheel studs come through? If the wheel studs spin a little, try putting a little booger in there with a welder. If you don't have a welder, knurl out the inside of the wheel stud hole in the hub with a punch to make em stick.
Old Jul 6, 2011 | 04:05 PM
Jeepers2003
That's what I did. I but a glob of loctite in to hold em until I could put some torque on them. Once I had pressure on the stud, they torqued fine. I was just concerned that they didn't seat in the splines. If it's not an issue, I'll just leave it as is and worry about replacing the hub later.
You think it will be OK?
Old Jul 6, 2011 | 04:19 PM
Jeepers2003
Wow... totally forgot about LMC. $50.00... Not bad at all.
Old Jul 6, 2011 | 04:20 PM
Jeepers2003
Strike that...119 for the 4WD
Old Jul 6, 2011 | 11:56 PM
wyckedcombo17
I think it'll be okay. Personally I used JB Weld and that shtuff works better than... I don't know what but it'll work better than anything else me or you can think of! It stands up to the heat on the intake manifold (choke tube on my 2150) so it'll handle the heat of a hub and drum/rotor.
I'm a big backer of JB weld for the poor man without a welder or just the man in a quick pinch
Old Jul 7, 2011 | 12:38 AM
ford1977owner
i never had luck with jb weld, i had a 4 wheeler once and my clutch handle snapped and jb weld didnt fix it =/ haha
Old Jul 7, 2011 | 07:13 AM
Steel Toy's Avatar
Steel Toy
I bought new hubs from Rockauto, info is in my 79 build thread link if that helps.
Old Jul 7, 2011 | 11:39 AM
tbear853's Avatar
tbear853
On my '92 T-bird I had a leak that kept reoccurring at the back of the AC compressor where the manifold bolts on. When not leaking, it worked great but then it would leak on a hot day. I had tried new O rings. Problem was that sometime in the past before I bought the car, someone had broken out a small part of the aluminum wall around the O ring. It's a place where the casting was thin. J B quick weld would work short term putting in place, but not long.
I pulled the manifold off, cut a piece of aluminum shim stock the width of the Oring groove's depth, about 1/2" long. Took a new O ring and just barely shaved it on the outside. Slipped the O-ring and shim stock in place, a new O ring beside it, put the manifold back on and cleaned the outer side good removing all old J B Weld. Applied new regular slow set J B Weld which has a higher temp rating, let harden overnight, vacume, then new R-134a, and that was several years ago. She's fixed now.
J B Weld is good stuff.
Loumos4
Dec 20, 2015 06:17 PM
brobrad
Oct 7, 2015 02:40 PM
crobotti
Apr 9, 2014 10:35 AM
dhag911
Dec 12, 2013 03:00 AM
f2fifty83diesel
16
Nov 13, 2012 06:06 PM
