I was using a test light to check power at the fuel shut off solenoid and accidentally grounded it out. I did have power at first but no power now and have checked the fuses and everything is good there and the power distribution box under the brake booster. I was tracing wires from the solenoid and found a little black square module with 4 wires going to it (has 1811164C2) on it. Could this be like a sealed fuse ??? I am stumped on this one !
I also have to use starting fluid every time I start it as there seems to be no power going through the solenoid for the glow plugs in which I am going to replace
I have the driveway blocked and need to get thing going, can anyone help me please
