The VC-9 is an iron/scale remover often referred to as an industrial class boiler cleaner. I know when I flushed mine the internal metal that I could see looked virgin in appearance. Almost like it had been bead blasted.
New oil cooler at beggining stages of plugging.did the restore flush before changing it to a tee,then ran gallons upon gallons through the system.now I'm getting scale flakes out of my radiator constantly.its gotten better,but unless its perfect ill keep going.got the vc9, that'll be my next step.the scale looks like calcium deposits.bought the truck used so I'm thinking I inherited lack of maintainance.thought about old schooling it and running cascade in it before the vc9.it never ends...
Simple Green won't touch rust/scale. If you want to clean your coolant system really well, it takes more than one step. First you want to remove any sludge in the system with an alkaline cleaner like Fleetguard Restore. After that is flushed out with water, then you want to use an acidic cleaner like Restore Plus or Motorcraft VC-9 to remove any rust and scale and to prep the metal surface for the new coolant to bond to it. After several flushes with distilled water, until clean, add your coolant. I recommend Fleetguard, CAT or another brand ELC coolant rather than Ford Gold. Add 3.5 gallons concentrate, then top off with distilled water to get the correct concentration.
I did both restore flushes just like instructed and thought it was clean.been flushing my rad for 6hours,no lie,and still getting scale out.it breaks apart easily when touched
It takes a lot of flushing, took me the better part of a day to flush my dad's '03. If you are just using the radiator drain, it will take a lot longer. I pulled the driver's side block plug and that got a lot more out each time.
I thought the vc-9 was just for rust but if its for scale to Id dump at least 2 quarts in make it strong run it then let it soak for awhile then run it again before you flush the vc-9 out give it plenty of time to break the scale down
Then stuff a hose in and try reverse flush where the thermistate goes with drain plugs out radiator and driver block might even consider pulling the passenger block drain plug out since it sounds like its full of junk
pull the lower radiator hose to junk always seamed to get traped there
[QUOTE=cartmanea;10504869]It takes a lot of flushing, took me the better part of a day to flush my dad's '03. If you are just using the radiator drain, it will take a lot longer. I pulled the driver's side block plug and that got a lot more out each time.[/QUOTi made an adapter for the top of rad,been holding my hand on the bottom port and getting a good wooosh if water out og itnyou may be on to something 69.I ran tap in it but no longer than day or two,then flushed with distilled.currently havr bottom hose and driver plug out with the hose stuffed in the cooler.finally have a summer day here in wa state and here I am.should be kicked back with beer in hand,waiting for the race to come on.after pricing a 11 f350 I gotta get my truck right.62k will buy a lot of 6l long blocks!.
atleast your not trying to flush out after a poped oil cooler
62,000 for a 2011 6.7L WOW how did the engine compartment look like stuffed full or what any room to do anything I saw a pic of a 6.4 and it didnt look very fun at all to get in and work on
Didn't even pop the hood.its urea injected though.buddy has a 6.4,it does look nightmarish if you ever had to work on it.well......in with the vc9 and about an hour drive.
